주요 콘텐츠로 건너뛰기
How to install the Xbox One Wireless Receiver (1713, Windows 10/11)
  1. How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Plug and play/Windows update: 1 단계, 이미지 3개 중 1개 How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Plug and play/Windows update: 1 단계, 이미지 3개 중 2개 How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Plug and play/Windows update: 1 단계, 이미지 3개 중 3개
    • If you have the Model 1790 (Slim) receiver, use the following driver: Xbox - Net - 10.46.1 driver.
    • Plug your Xbox Wireless Receiver into your PC. Proceed further if the automatic installation fails.
    • Locate Other Devices. Without a driver installed, the receiver will be found here.
    • Double click XBOX ACC and check for Code 28. Click Update Driver and you will see a window with two options.
    • Before manually installing the driver, select Search automatically for updated driver software. Install the driver manually if this fails.
  2. How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Plug and play/Windows update (Windows 10): 2 단계, 이미지 3개 중 1개 How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Plug and play/Windows update (Windows 10): 2 단계, 이미지 3개 중 2개 How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Plug and play/Windows update (Windows 10): 2 단계, 이미지 3개 중 3개
    • Author's note: Windows 10 is end of life as of October 14, 2025. If Microsoft breaks the Windows Update driver option, you may need to use the manual method.
    • Unlike Windows 7/8.x, this method (generally) works well. However, Windows 11 may need help from Windows Update if the automatic Device Manager search fails due to the age of the receiever.
    • The "virgin" installation messaging may differ slightly which was not shown on this laptop due to prior installations. Select Search automatically for drivers.
    • NOTE: THESE STEPS ARE NOT SHOWN ON MY COMPUTER AS IT TENDS TO WORK THE FIRST TIME WITH MINE. Click Search for updated drivers on Windows Update. Once this is done, the driver will be installed.
    • Click Check for updates to ensure the driver will download if the system is unresponsive. Once completed, the receiver should work.
  3. How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Plug and play/Windows update (Windows 11): 3 단계, 이미지 3개 중 1개 How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Plug and play/Windows update (Windows 11): 3 단계, 이미지 3개 중 2개 How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Plug and play/Windows update (Windows 11): 3 단계, 이미지 3개 중 3개
    • These steps are similar to the steps found in Windows 10, but there are minor differences.
    • Click on Windows Update.
    • After plugging your receiver into your PC, click on Check for updates. The receiver will show up and download the correct driver.
    • Once the driver is installed, check to make sure the receiver shows in Device Manager correctly.
  4. How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Manual/Driver installation: 4 단계, 이미지 3개 중 1개 How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Manual/Driver installation: 4 단계, 이미지 3개 중 2개 How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Manual/Driver installation: 4 단계, 이미지 3개 중 3개
    • If the driver does not automatically get downloaded, search for "Xbox Wireless" in the Microsoft Update Catalog. Select the following driver: Microsoft - Net - 8/26/2015 12:00:00 AM - 19.16.17.976 or Microsoft - Other hardware - Xbox Wireless Adapter for Windows.
    • Select Browse my computer for driver software.
    • Locate the folder where the driver is located and select Copy address as text. Paste the location into the search box. Click Next.
  5. How to install the Xbox One Wireless Receiver (1713, Windows 10/11), Verify the installation: 5 단계, 이미지 1개 중 1개
    • To verify the driver was installed correctly, check under Network Adapters. If the driver was installed correctly, it will show up here.
결승점
다른 29명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Nick
회원 가입일: 11/10/09
98,602 평판
안내서 63개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,451개를 작성함
49가이드 댓글
Hi Nick,
This is a great guide. It seems to be a common issue and many people have offered similar solutions, but this one is the clearest and most well-explained.
However, it didn’t work for me - and from comments I’ve seen around, I know I’m not the only one. I wonder if you have any thoughts on this?
At the end of Step 3 (“Click Next and install the driver”), the window flashes to something like “Searching location…” for less than a second and then I get:
Windows was unable to install your XBOX ACC
Windows could not find drivers for your device.
If you know the manufacturer of your device, you can visit their website and check the support section for downloadable drivers.
I’m using Win 10 64-bit, fully updated.
I’ve tried the other drivers on the Update Catalog with the same result.
Is it possible to manually force the drivers to be installed?
Thanks,
Eryn
ErynExtremelyOnline - 답글
You can actually download the driver manually to force the installation. To force the installation, you will need this driver for Win10: Microsoft driver update for Xbox Wireless Adapter for Windows (18.31.1.43)
If the issue is installation, you need to unzip the folder and put the files in a normal folder. The .cab folder from the download site doesn’t work as-is. I should have clarified this, but it’s corrected.
Nick -
Thanks, but that wasn’t my issue.
I figured out that you can use the “Have disk…” option in the driver update dialog to force the install, but that still didn’t fix it - Device Manager correctly identified the device as “Xbox Wireless Adapter”, but it showed error code 10 and still failed to work.
What actually fixed it was a NEWER, entirely different (and deceptively named) driver in the Update Catalog.
For 64-bit systems:
Title: Xbox - Net - 7/11/2017 12:00:00 AM - 1.0.46.1
Products: Windows 10 Anniversary Update and Later Servicing Drivers,Windows 10 S and Later Servicing Drivers
Classification: Drivers (Networking)
Last Updated: 7/11/2017
Version: 1.0.46.1
For x86 systems:
Version: 1.0.46.1
I really hope this helps anyone else out there with the same issues as me.
Eryn
I did it on a W10 Build 1708 system with deferred updates and the throttled internet connection option enabled. I think 1708 is the Anniversary update, so there’s a chance that system had an older build at the time.
Nick -
Yeah, that makes sense.
I also just realised that your guide is for the original Wireless Adapter - whereas I’ve got the new (smaller) one. Maybe add a note that owners of the newer adapter will also need the newer driver?
None of the other guides I’ve seen out there include this info either, and yours is still the easiest to follow… so you’re still winning :)
댓글 쓰기
조회 통계:
지난 24시간: 54
지난 7일: 452
지난 30일: 1,720
전체 시간: 199,681
