주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to know the manufacture's date of an automobile battery before buying it?
  1. How to know the manufacture's date of an automobile battery before buying it?, How to know the manufacture's date of an automobile battery before buying it?: 1 단계, 이미지 2개 중 1개 How to know the manufacture's date of an automobile battery before buying it?, How to know the manufacture's date of an automobile battery before buying it?: 1 단계, 이미지 2개 중 2개
    • Brief document on how to locate the date of manufacture of an automobile battery, some have it silkscreened in the superior part in a lateral part, some in a terminal with die-cut numbering, but the majority of batteries have it indicated in the worst place and the most uncomfortable and complicated to review, IN THE BASE OF THE BATTERY.
    • The battery used in this example has been removed from an automobile, as it had reached the end of its useful life, it was already showing signs of not starting properly, it has lasted from 04/12/2016 to 27/01/2023 just over 6 years.
    • What is the useful life of a car battery? The answer is simple, it depends on the country where you buy it, it is purely a matter of PROGRAMMED OBSOLESCENCE, that is to say, in Spain and Europe, that our sales guarantee is 2 years, the batteries last an average of 4 to 5 years, they would last more if distilled water could be replaced, nowadays.
    • The batteries come sealed with NO MAINTENANCE, when it is a lie, you need to replenish water, otherwise they do not last.
    • In Central and South American countries, the sales warranty is 1 year, so batteries usually last 2 to 3 years at the most.
    댓글 쓰기
  2. How to know the manufacture's date of an automobile battery before buying it?: 2 단계, 이미지 2개 중 1개 How to know the manufacture's date of an automobile battery before buying it?: 2 단계, 이미지 2개 중 2개
    • The example battery in this document was purchased and installed on 04/12/2016 as seen in the photo (When I install them in the car, I put a dymo tape with the date of installation. Now we will see how to see when it was manufactured.)
    댓글 쓰기
  3. How to know the manufacture's date of an automobile battery before buying it?: 3 단계, 이미지 3개 중 1개 How to know the manufacture's date of an automobile battery before buying it?: 3 단계, 이미지 3개 중 2개 How to know the manufacture's date of an automobile battery before buying it?: 3 단계, 이미지 3개 중 3개
    • In several brands of batteries, the manufacturers place the date of manufacture on the base of the battery, so it is quite difficult to check that date easily, it is indicated in 2 circles with a numbering and a date.
    • Note: This is the date of manufacture of the battery housing. But the battery itself should be about the same age.
    댓글 쓰기
  4. How to know the manufacture's date of an automobile battery before buying it?: 4 단계, 이미지 2개 중 1개 How to know the manufacture's date of an automobile battery before buying it?: 4 단계, 이미지 2개 중 2개
    • Detail photos of the 2 circles.
    댓글 쓰기
  5. How to know the manufacture's date of an automobile battery before buying it?: 5 단계, 이미지 3개 중 1개 How to know the manufacture's date of an automobile battery before buying it?: 5 단계, 이미지 3개 중 2개 How to know the manufacture's date of an automobile battery before buying it?: 5 단계, 이미지 3개 중 3개
    • The circle on the left side, numbered from 1 to 12, indicates the MONTH OF CONSTRUCTION, in this example, 6 = JUNE.
    • The circle on the right, varies according to the years, this example marks 16 - 17 - 18 - 19 - 20 - 21 with the arrow pointing to 16, so it indicates the year of manufacture, 2016.
    • Dates we can ascertain with the sticker of when it was installed, Manufactured: 06/ 2016 Installed 04/12/2016.
    댓글 쓰기
결론
How to locate the date of manufacture on many automotive batteries.
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
es en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Carlos López (España - Spain)
회원 가입일: 07/01/15
100,407 평판
안내서 362개를 작성함
14가이드 댓글
Date pour Batterie Bosch Z5G211103 1385
merci du retour info
Jean Jacques Thomas - 답글 공유
Jean Jacques Thomas Hola, si no usa el mismo metodo que he indicado alguna lleva sertigrafia en el plastico superior o en el borne, si no esta en ninguno de estos sitios, no se donde la llevan.
Carlos López (España - Spain) - 답글 공유
Bonjour
Ce n’est pas la date de fabrication de la batterie mais celle de l’emballage de la batterie Ces 2 dates se font lorsque l’injection du plastique se crée. C’est pourquoi elle sont sous la batterie. La date de la batterie se fait avec les chiffres et les lettres avec les caractéristiques de la batterie
michel@mpoget.ch - 답글 공유
Gracias por el aporte
Hola. La vida útil de las baterías? Comienza desde el primer momento en que fue reactivada. (Cuando le pusieron el acido).
Juan Ramon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 61
지난 7일: 555
지난 30일: 2,339
전체 시간: 129,506
