주요 콘텐츠로 건너뛰기
How to load HP Deskjet 6122 paper
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
  1. How to load HP Deskjet 6122 paper, How to load HP Deskjet 6122 paper: 1 단계, 이미지 1/1
    • Open the paper tray to see if it is empty.
  2. How to load HP Deskjet 6122 paper: 2 단계, 이미지 1/1
    • If the paper tray is empty, add paper to the tray.
    • If there is already paper in the tray, realign the paper so that it fits in the gears, and can feed through properly.
  3. How to load HP Deskjet 6122 paper: 3 단계, 이미지 1/1
    • Ensure that all paper is in the correct tray.
    • The correct tray is on the upper deck of the printer.
  4. How to load HP Deskjet 6122 paper: 4 단계, 이미지 1/1
    • Run the printer to verify it now prints.
    • If the paper still does not run through the printer, inspect the paper tray again.
  5. How to load HP Deskjet 6122 paper: 5 단계, 이미지 1/1
    • Remove any paper that looks to be overloading the tray feeder.
    • Sometimes there can be too much paper in the tray, preventing it from working properly.
  6. How to load HP Deskjet 6122 paper: 6 단계, 이미지 1/1
    • Try to print one last time. If it still fails, consider consulting a page to update drivers.
결론
Joe
회원 가입일: 10/14/11
1 평판
안내서 4개 작성하였습니다
James Madison, Team 2-5, Allen Fall 2011 James Madison, Team 2-5, Allen Fall 2011 회원
JMU-ALLEN-F11S2G5
1 회원
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 866
