소개
If your hand mixer sounds rough or runs hot, the bronze bushings and gears inside are probably dry. A light cleaning and proper lubrication keeps the motor cool, stops wear, and can add years to the machine’s life. This guide shows you, a home user, exactly how to open most standard hand mixers, clean away flour and sugar, oil the shaft bushings, grease the gears, and reassemble the appliance. Work carefully, follow the cautions, and confirm whether opening the housing affects any active warranty before you start.
필요한 것
1 단계 Disconnect power and gather tools
Lay a non-slip mat on a stable bench and arrange your screwdrivers, brush, oil, grease, vacuum, and paper towel within reach.
2 단계 Remove external screws
Locate the three Phillips screws on the underside of the mixer housing.
Remove the screws with a Phillips screwdriver and keep them in a safe place.
3 단계 Separate the upper housing
Slide the beater-eject switch to the eject position to release the plastic clips.
4 단계 Inspect motor and avoid sensitive parts
Identify the two bronze bushings at each end of the rotor shaft; these are the primary lubrication points.
5 단계 Remove gear carrier assembly
Carefully pull the beater carrier plate off the gear train.
Lift the two gears and the small spacer pin straight out and set them aside in order.
7 단계 Oil the motor shaft bushings
Apply one drop of light machine oil onto the rear bushing where the shaft enters the motor frame.
Move the rotor up and down a few millimetres to draw oil into the bushing.
Repeat on the front bushing beside the cooling fan.
8 단계 Grease the gear teeth and shafts
Spread a thin layer of medium grease onto the gear teeth and smooth bearing surfaces.
9 단계 Seat gears in correct orientation
Holding the greased gears, align the cross-shaped beater sockets so one is vertical–horizontal while the other is diagonal.
Lower both gears and the spacer back into the housing without disturbing their position.
10 단계 Lubricate and fit spacers and carrier
Lightly grease the metal washers and slide them onto the gear spindles.
Reinstall the plastic carrier plate, making sure its tabs seat in the housing slots.
11 단계 Reinstall speed selector and eject mechanism
Position the speed control and eject lever back into their tracks, pressing gently until they click.
Ensure the selector lines up with the notch on both sides of the housing.
12 단계 Close housing and secure screws
Lower the upper housing onto the base, squeezing slightly until it seats evenly.
Install the three Phillips screws and tighten them firmly but not excessively.
13 단계 Function test
Plug the mixer in and run it without beaters; it should spin smoothly and quietly like a sewing machine.
14 단계 Service interval and warranty reminder
Regular lubrication prevents overheating and extends service life.
Your mixer should now run quietly and stay cool under load. Repeat this maintenance whenever the motor noise increases or at least every few years if you use the appliance frequently. Keeping the bushings oiled and the gears greased is the simplest way to postpone costly repairs or replacement.
