소개
This guide shows you how to clean and maintain the most common household air regenerators—humidifiers, air purifiers, portable air-conditioners and insect traps. Performing these simple tasks keeps the appliances quiet, efficient and hygienic, while helping them last longer. Always work safely and respect the manufacturer’s instructions and warranty conditions before touching any device.
필요한 것
2 단계 Recognise common air regenerator types
Mechanical humidifiers that use a vibrating turbine to create a visible mist.
Compact ultrasonic humidifiers evaporate about 250–300 ml of water in a few hours.
Air purifiers trap smoke, mites and odours with replaceable filters.
Portable air conditioners use R410A gas with washable rear filters and a condenser section.
Insect traps lure pests with a UV lamp and move air with a small fan.
3 단계 Clean the ultrasonic humidifier
Vacuum or gently blow dust from the small bottom fan to restore airflow.
Pour a small amount of white vinegar or dissolved citric acid into the tank to dissolve scale.
Add water, let the solution sit, then rinse and wipe the reservoir thoroughly.
4 단계 Disassemble the mechanical humidifier
Lift out the motor module and pull the cable clear for safe access.
Remove the circular ring and unscrew the large central screw to free the turbine assembly.
Soak separated parts in a vinegar or citric acid bath to loosen mineral deposits.
Scrub grooves, fins and the turbine with an old toothbrush until clean.
5 단계 Reassemble the mechanical humidifier
Rinse all components with clean water and dry them completely.
Reinstall the turbine, screw, ring and motor module in the reverse order.
6 단계 Dust off air purifier filters
Tap each filter against a solid wooden edge outdoors to knock out trapped particles.
Lightly vacuum the filter surface and blow from a safe distance to finish cleaning.
7 단계 Refit and purge the air purifier
Return the cleaned filters to their original slots and secure the cover firmly.
Power the unit briefly so the fan expels any residual dust left inside.
8 단계 Clean portable AC upper filters and sensors
Remove the rear filters and wash or vacuum them thoroughly.
Brush dust off sensors and surrounding plastics with a soft brush.
Vacuum or blow out the filter frame and housing depending on available tools.
9 단계 Clean portable AC condenser section
Open the lower grille to expose the condenser and compressor area.
Wash or vacuum the lower filter because it governs cooling efficiency.
Use an air compressor to blow debris from coils and channels while maintaining a safe distance.
10 단계 Purge and reinstall portable AC filters
Run the unit in fan-only mode before reassembly to expel hidden dust.
Fit the dry filters into their grooves, aligning notches accurately.
Close the covers and confirm the appliance operates smoothly for hot days ahead.
11 단계 Clean the insect remover
Disconnect the unit and remove the two screws that hold the housing together.
Vacuum or blow out interior dust that accumulates during nightly operation.
Clean the external grille and debris collector before reassembly.
12 단계 Reassemble the insect trap
Align the housing, locate screw holes and reinstall the fasteners with light torque.
Return the trap to its usual spot so it can resume pest control duties.
Regular cleaning with simple household tools keeps your air regenerators efficient and extends their service life. Always unplug first, work gently and follow the appliance maker’s instructions. If you encounter damage or uncertainty, contact an authorised technician instead of forcing a repair.
