주요 콘텐츠로 건너뛰기
How to make Dyson AM07 (more) useable!
필요한 것
  1. How to make Dyson AM07 (more) useable!, Overview and button names: 1 단계, 이미지 1개 중 1개
  2. How to make Dyson AM07 (more) useable!, Add some dots!: 2 단계, 이미지 2개 중 1개 How to make Dyson AM07 (more) useable!, Add some dots!: 2 단계, 이미지 2개 중 2개
    • Plug in your glue gun and let it heat up.
    • I made a big dot on the oscillation button, another one on the Standby ON/OFF button, and two more dots (big and small) on the Airflow control buttons. I don't use the Sleep Timer so I haven't added any dots to those two buttons.
    • If you don't get it right on the first try, don't worry. Just wait a couple of seconds for the glue to cool down and remove the dot. The glue comes off without leaving any residue or marks on the plastic.
  3. How to make Dyson AM07 (more) useable!, Bonus points: make shapes: 3 단계, 이미지 2개 중 1개 How to make Dyson AM07 (more) useable!, Bonus points: make shapes: 3 단계, 이미지 2개 중 2개
    • I used a carpet cutter (sharpest knife I had lying around) to cut the dot on the Standby ON/OFF button into an "I" shape for a little bit of different tactile feedback.
    • Some more ideas for customization: while the glue is still fluid, stick little parts of plastic, for example, in it to get different kind of buttons.
  4. How to make Dyson AM07 (more) useable!, The result: 4 단계, 이미지 3개 중 1개 How to make Dyson AM07 (more) useable!, The result: 4 단계, 이미지 3개 중 2개 How to make Dyson AM07 (more) useable!, The result: 4 단계, 이미지 3개 중 3개
    • They could look better but the buttons are a lot more useable now, in my opinion.
결론
To undo these changes and restore your remote, just peel off the dots.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Frank
회원 가입일: 06/08/15
85 평판
안내서 1개를 작성함
4가이드 댓글
I would not recommend this. I would just order custom buttons and use some 3m tape to attach to the remote. Also, I don't have any problems finding the right buttons in the dark to control my fan.
kayshawncartel - 답글
Good for you. Then just ignore this guide.
Frank -
Bit a crap mod me thinks… not well thought out… its pretty obvious that if you do this the control will no longer sit nicely on top of the fan! Better off learning your left from your right ;-)
Abdullah Khan - 답글
Useful, but not sure about the appearance.
I’m interested in how to alter a Dyson Hot & Cold fan bought in the UK for use in the US…if anyone has recommendations?
James Bowkett - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 74
전체 시간: 15,135
