주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to make Dyson AM07 (more) useable!
조회수: 1.7만
통계 보기:
지난 24시간
3
지난 7일:
24
지난 30일:
133
전체 시간:
17,220
댓글: 6
2 comments on steps, 4 guide comments.
Go to guide comments
완료함: 4
4명이 이 안내서를 "완료"로 표시했습니다. 다음은 귀하의 차례입니까?
즐겨찾기: 0
해당 안내서에 좋아요를 누르고 구독한 사람이 아직 없습니다. 첫 번째 주인공이 되시겠습니까?
소요 시간: 2 - 5 분
난이도: 쉬움
커뮤니티-기여 안내서
이 안내서는 저희 커뮤니티의 멋진 회원이 작성하였습니다. iFixit 직원이 작성하지 않습니다.
The remote control for the Dyson AM07 (and possibly other Dyson fans and heaters - I only own the AM07, so I don't know) has a sleek design, but unfortunately it's a case of "function follows form".
Without looking at it, you can't tell where the buttons are and what they do because they are flush with the rest of the thing. Which makes this remote not very useable, especially at night.
Luckily, there's a very easy (and reversible) fix for this. All you need is a glue gun! :)
필요한 것
도구
    1. How to make Dyson AM07 (more) useable!, Overview and button names: 1 단계, 이미지 1개 중 1개
      댓글 쓰기
    2. How to make Dyson AM07 (more) useable!, Add some dots!: 2 단계, 이미지 2개 중 1개 How to make Dyson AM07 (more) useable!, Add some dots!: 2 단계, 이미지 2개 중 2개
      • Plug in your glue gun and let it heat up.
      • I made a big dot on the oscillation button, another one on the Standby ON/OFF button, and two more dots (big and small) on the Airflow control buttons. I don't use the Sleep Timer so I haven't added any dots to those two buttons.
      • If you don't get it right on the first try, don't worry. Just wait a couple of seconds for the glue to cool down and remove the dot. The glue comes off without leaving any residue or marks on the plastic.
      댓글 쓰기
    3. How to make Dyson AM07 (more) useable!, Bonus points: make shapes: 3 단계, 이미지 2개 중 1개 How to make Dyson AM07 (more) useable!, Bonus points: make shapes: 3 단계, 이미지 2개 중 2개
      • I used a carpet cutter (sharpest knife I had lying around) to cut the dot on the Standby ON/OFF button into an "I" shape for a little bit of different tactile feedback.
      • Some more ideas for customization: while the glue is still fluid, stick little parts of plastic, for example, in it to get different kind of buttons.
      댓글 쓰기
    4. How to make Dyson AM07 (more) useable!, The result: 4 단계, 이미지 3개 중 1개 How to make Dyson AM07 (more) useable!, The result: 4 단계, 이미지 3개 중 2개 How to make Dyson AM07 (more) useable!, The result: 4 단계, 이미지 3개 중 3개
      • They could look better but the buttons are a lot more useable now, in my opinion.
      댓글 쓰기
결론
To undo these changes and restore your remote, just peel off the dots.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자
Frank
회원 가입일: 06/08/15
85 평판
안내서 1개를 작성함
4가이드 댓글
I would not recommend this. I would just order custom buttons and use some 3m tape to attach to the remote. Also, I don't have any problems finding the right buttons in the dark to control my fan.
kayshawncartel - 답글 공유
Good for you. Then just ignore this guide.
Frank - 답글 공유
Bit a crap mod me thinks… not well thought out… its pretty obvious that if you do this the control will no longer sit nicely on top of the fan! Better off learning your left from your right ;-)
Abdullah Khan - 답글 공유
Useful, but not sure about the appearance.
I’m interested in how to alter a Dyson Hot & Cold fan bought in the UK for use in the US…if anyone has recommendations?
James Bowkett - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 133
전체 시간: 17,220
