주요 콘텐츠로 건너뛰기
How to manually Unload Filament on an Ender 3 Pro
  1. How to manually Unload Filament on an Ender 3 Pro, Setting the nozzle temperature: 1 단계, 이미지 3개 중 1개 How to manually Unload Filament on an Ender 3 Pro, Setting the nozzle temperature: 1 단계, 이미지 3개 중 2개 How to manually Unload Filament on an Ender 3 Pro, Setting the nozzle temperature: 1 단계, 이미지 3개 중 3개
    • Press the knob to enter the marlin LCD menu and turn it to navigate between the options.
    • Navigate to Temperature > Nozzle.
    • Adjust the nozzle temperature by turning the knob and confirm by pressing it.
    • Use whatever temperature you would be printing with, minus about 10°C. For both PLA and PETG 210°C usually works fine.
  2. How to manually Unload Filament on an Ender 3 Pro, Wait for the hotend to heat up: 2 단계, 이미지 1개 중 1개
    • Wait until the current temperature (bottom) matches the target temperature (top).
  3. How to manually Unload Filament on an Ender 3 Pro, Pull the filament: 3 단계, 이미지 1개 중 1개
    • Press down on the extruder lever arm and pull out the loaded filament.
    • Fully pressing down the lever arm might lead to the filament snagging when you try to pull it out. Just pressing it a bit will usually suffice.
  4. How to manually Unload Filament on an Ender 3 Pro, Set cooldown: 4 단계, 이미지 1개 중 1개
    • Navigate to Temperature and press Cooldown.
    • If you do not have the Cooldown-option available, you can just repeat step one and set the temperature to 0°C instead.
결론
This guide also applies to loading filament. You just need to push in the filament instead of pulling it out.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
31,061 평판
안내서 71개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 57
전체 시간: 2,033
