주요 콘텐츠로 건너뛰기
How to open Logitech Z130 speakers
필요한 것
  1. How to open Logitech Z130 speakers, Getting prepared: 1 단계, 이미지 1개 중 1개
    • Warning: Unplug the device from power before you start!
    • Unplug the audio cable as well
  2. How to open Logitech Z130 speakers, Remove the rear screws: 2 단계, 이미지 1개 중 1개
    • At the rear of the speaker, remove two screws.
  3. How to open Logitech Z130 speakers, Remove the front screws: 3 단계, 이미지 2개 중 1개 How to open Logitech Z130 speakers, Remove the front screws: 3 단계, 이미지 2개 중 2개
    • Two front screws are hidden by the speaker grid
    • Simply by pulling it, remove the speaker grid
    • Remove the two screws which are now apparent
  4. How to open Logitech Z130 speakers, Remove the volume button and its nut: 4 단계, 이미지 3개 중 1개 How to open Logitech Z130 speakers, Remove the volume button and its nut: 4 단계, 이미지 3개 중 2개 How to open Logitech Z130 speakers, Remove the volume button and its nut: 4 단계, 이미지 3개 중 3개
    • Remove the volume button by pulling it
    • Unscrew the nut which is now exposed
    • Remove the nut and the spacer
  5. How to open Logitech Z130 speakers, Remove the bottom screws: 5 단계, 이미지 2개 중 1개 How to open Logitech Z130 speakers, Remove the bottom screws: 5 단계, 이미지 2개 중 2개
    • Two front screws are hidden by a pad below the speaker.
    • Remove the pad
    • Remove the two bottom screws.
  6. How to open Logitech Z130 speakers, Open the speaker: 6 단계, 이미지 1개 중 1개
    • Job's done, you are now able to open the speaker by gently pulling the front part of it.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Benoit74
회원 가입일: 11/15/21
3,398 평판
안내서 11개를 작성함
3가이드 댓글
Thanks for this - I needed to open up my Z130 to spray contact cleaner in the volume potentiometer. No more breakup when turning the volume knob!
Jesse Smith - 답글
Whew! I was ruining the speaker plastic trying to pry this thing apart. Now I see I need to take out the two screws under the speaker grill!
Frank Zimmerman - 답글
Getting the speaker grill off was difficult - I had to insert a screwdriver and lever it upwards, bending the edge of the grill which later had to be straightened when I reassembled it.
Simon Kravis - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 87
전체 시간: 3,496
