오래된 번역입니다: 번역을 업데이트하여 돕거나 소스 안내서를 확인하여 주십시오.
소개
To open a cell phone with a 3D printer sounds bizarre, I know. But as long as you have a reasonably new 3D printer, it's actually very easy.
The requirements are simple: the printer should have a strong, heated print bed. That's all!
필요한 것
First, turn on your 3D printer and make sure that there are no objects (such as plastic left on it) on the print bed.
Put the cell phone on the print bed and set yourself a timer of 30 seconds.
This should be sufficient for these purposes. However, if the phone is still too cool, you can put it on for another 15 seconds.
When you're done, you can take the phone off the print bed and start fooling around on it.
You are done, congratulations!
다른 4명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
50%
knipwim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
