주요 콘텐츠로 건너뛰기
How to open the 2007-2012 Jeep Wrangler hood
필요한 것
  1. How to open the 2007-2012 Jeep Wrangler hood, How to open the 2007-2012 Jeep Wrangler hood: 1 단계, 이미지 1/2 How to open the 2007-2012 Jeep Wrangler hood, How to open the 2007-2012 Jeep Wrangler hood: 1 단계, 이미지 2/2
    • Locate the two grey latches on each side of the hood near the headlights.
    • Pull the latches away from the hood to release the latches.
  2. How to open the 2007-2012 Jeep Wrangler hood: 2 단계, 이미지 1/2 How to open the 2007-2012 Jeep Wrangler hood: 2 단계, 이미지 2/2
    • Reach underneath the hood and push up on the lever located in the front center of the hood. You can now open the hood.
    • Prop the hood open by inserting the hood support rod into the designated hole on the underside of the hood.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ryan Smith
회원 가입일: 09/26/12
287 평판
안내서 1개 작성함
Cal Poly, Team 7-51, Forte Fall 2012 Cal Poly, Team 7-51, Forte Fall 2012 회원
CPSU-FORTE-F12S7G51
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 65
전체 시간: 24,355
