주요 콘텐츠로 건너뛰기
How to open the Huawei Watch GT 2e
필요한 것
  1. How to open the Huawei Watch GT 2e, Turn off the watch: 1 단계, 이미지 2개 중 1개 How to open the Huawei Watch GT 2e, Turn off the watch: 1 단계, 이미지 2개 중 2개
    • Turn off the watch:
    • Press and hold the top button for >3 sec.
    • Tap "Power off".
    • Push the small sliding nub on one of the watch band pins inwards toward the center of the watch band.
    • While holding the nub in, pull one side of the pin out of its recess on the watch housing, then the other side.
    • Remove the band.
    • Repeat this process to remove the second band.
  2. How to open the Huawei Watch GT 2e, Remove the four rear screws: 3 단계, 이미지 1개 중 1개
    • Remove the four 3.5 mm-long T3 Torx screws on the back of the watch.
  3. How to open the Huawei Watch GT 2e, Open a small gap: 4 단계, 이미지 3개 중 1개 How to open the Huawei Watch GT 2e, Open a small gap: 4 단계, 이미지 3개 중 2개 How to open the Huawei Watch GT 2e, Open a small gap: 4 단계, 이미지 3개 중 3개
    • Place the point of a spudger in the small hole on the side of the rear case.
    • Use the spudger to push the rear case away from the housing to create a small gap. Use steady force to separate the two parts.
    • Steady the rear case with a finger to avoid it suddenly popping open and damaging the flex cable.
    • Don’t open the rear case all the way just yet. It is still connected to the motherboard with a thin flex cable.
  4. How to open the Huawei Watch GT 2e, Flip the rear case open: 5 단계, 이미지 3개 중 1개 How to open the Huawei Watch GT 2e, Flip the rear case open: 5 단계, 이미지 3개 중 2개 How to open the Huawei Watch GT 2e, Flip the rear case open: 5 단계, 이미지 3개 중 3개
    • Flip the rear case assembly open towards the buttons to access the interconnect flex cable connector.
  5. How to open the Huawei Watch GT 2e, Remove the bracket screw: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $3.99
    • Remove the 2.5 mm-long Phillips screw securing the interconnect cable bracket.
    • When re-assembling you might need a pair of pointy angled tweezers to position the screw since they are non-ferrous and therefore don’t stick to the magnetic bit.
  6. How to open the Huawei Watch GT 2e, Remove the bracket: 7 단계, 이미지 3개 중 1개 How to open the Huawei Watch GT 2e, Remove the bracket: 7 단계, 이미지 3개 중 2개 How to open the Huawei Watch GT 2e, Remove the bracket: 7 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to slide the interconnect cable bracket down and left to unlatch it.
    • Remove the interconnect cable bracket.
    • For reassembly make sure to slide the bracket into place from bottom left towards top right to engage the small latch.
  7. How to open the Huawei Watch GT 2e, Unplug the flex cable: 8 단계, 이미지 3개 중 1개 How to open the Huawei Watch GT 2e, Unplug the flex cable: 8 단계, 이미지 3개 중 2개 How to open the Huawei Watch GT 2e, Unplug the flex cable: 8 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and unplug the interconnect cable.
    • Remove the rear case assembly.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answer Community for help.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
129,190 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 51
전체 시간: 3,666
