소개
Most repairs require the espresso machine to be opened. This is shown here. Please note that there are models with a decorative frame made of metal and others made of plastic (shown here).
These instructions may also help with other Saeco models and with coffee makers from Philips and Gaggia—they are all made by the same manufacturer and have a very similar design.
필요한 것
First check which model you have in front of you: Is the decorative frame made of chromed metal (picture 1) or of metallized plastic? (picture 2). In the first case follow this guide, in the second case you are in the right place here.
Lay the machine on its side. Now you can lift off the side panel. There is a small notch in the top right and it is probably still a bit stuck.
In principle, the side with the service flap could also be removed in a similar way, but this is not necessary for many repairs.
Picture 2 shows the Moltio with side panel open:
pump
flowmeter
PCB
heater
다른 8명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 2개
Super Bilderklärung mit den farbigen Hinweisen.
So und nicht anders ist es richtig erklärt.
