주요 콘텐츠로 건너뛰기
How to open the SteelSeries Nimbus+ Controller
필요한 것
  1. How to open the SteelSeries Nimbus+ Controller, Remove the phone mount: 1 단계, 이미지 2개 중 1개 How to open the SteelSeries Nimbus+ Controller, Remove the phone mount: 1 단계, 이미지 2개 중 2개
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. How to open the SteelSeries Nimbus+ Controller, Remove the sticker: 2 단계, 이미지 1개 중 1개
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. How to open the SteelSeries Nimbus+ Controller, Unscrew the back cover: 3 단계, 이미지 1개 중 1개
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: 4 단계, 이미지 2개 중 1개 How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: 4 단계, 이미지 2개 중 2개
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: 5 단계, 이미지 2개 중 1개 How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: 5 단계, 이미지 2개 중 2개
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: 6 단계, 이미지 2개 중 1개 How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: 6 단계, 이미지 2개 중 2개
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: 7 단계, 이미지 2개 중 1개 How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: 7 단계, 이미지 2개 중 2개
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: 8 단계, 이미지 3개 중 1개 How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: 8 단계, 이미지 3개 중 2개 How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: 8 단계, 이미지 3개 중 3개
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: 9 단계, 이미지 3개 중 1개 How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: 9 단계, 이미지 3개 중 2개 How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. How to open the SteelSeries Nimbus+ Controller, Remove the back cover assembly: 10 단계, 이미지 1개 중 1개
    • Remove the back cover assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
62,346 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,729개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 38
전체 시간: 1,822
