주요 콘텐츠로 건너뛰기
How to open up a Nokia N9
필요한 것
  1. How to open up a Nokia N9, remove top parts: 1 단계, 이미지 1/3 How to open up a Nokia N9, remove top parts: 1 단계, 이미지 2/3 How to open up a Nokia N9, remove top parts: 1 단계, 이미지 3/3
    • Click open the USB input protector lid and pull it from the housing.
    • Also remove the SIM card holder.
    • Remove screws from the top using the T3 torx screwdriver.
  2. How to open up a Nokia N9, loosen the screen: 2 단계, 이미지 1/3 How to open up a Nokia N9, loosen the screen: 2 단계, 이미지 2/3 How to open up a Nokia N9, loosen the screen: 2 단계, 이미지 3/3
    • Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone.
  3. How to open up a Nokia N9, disconnect screen from phone: 3 단계, 이미지 1/3 How to open up a Nokia N9, disconnect screen from phone: 3 단계, 이미지 2/3 How to open up a Nokia N9, disconnect screen from phone: 3 단계, 이미지 3/3
    • Using a plastic tool, carefully open up the distance between the screen and the housing until the screen is only attached with 2 cables.
    • With the same plastic tool, disconnect the screen cables still attached to the phone.
    • The screen is now separated from the rest of the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
knipwim
회원 가입일: 09/01/18
8,527 평판
안내서 30개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 34
전체 시간: 1,640
