소개
This guide will help you patch a dry wall hole using drywall joint compound, paint scraper and a cleaning tool (I'll be using wet kitchen tissue).
필요한 것
Clean up the area you want to patch with a wet soft cloth. Pat it dry.
Paint can be used after the compound has dried off to match your door's finish. There are guides available online to help you paint over the drywall compound.
다른 2명이 해당 안내서를 완성하였습니다.
