주요 콘텐츠로 건너뛰기
How to properly install the flex cable on the 4th Generation Touch
  1. How to properly install the flex cable on the 4th Generation Touch, How to properly install the flex cable on the 4th Generation Touch: 1 단계, 이미지 1/2 How to properly install the flex cable on the 4th Generation Touch, How to properly install the flex cable on the 4th Generation Touch: 1 단계, 이미지 2/2
    • Esta es la forma correcta de doblar el cable flex de la pantalla.
    • English: This is the correct way to bend the flex cable to the display.
  2. How to properly install the flex cable on the 4th Generation Touch: 2 단계, 이미지 1/1
    • No doblar el cable flex de esta forma.
    • English: Do not bend the flex cable this way.
  3. How to properly install the flex cable on the 4th Generation Touch: 3 단계, 이미지 1/1
    • Al doblar el cable flex de forma incorrecta la pantalla no entra completamente en el socket y se quiebra al tratar de cerrar el iPod.
    • English: When bending the flex cable incorrectly the screen does not fit completely into the socket and breaks when trying to close the iPod.
결론
다른 12명이 해당 안내서를 완성하였습니다.
fibocellphone
회원 가입일: 03/28/14
577 평판
안내서 1개 작성함
댓글 한 개
after replacing flex cable is not working so touch is not responding ,display is good ....how I can fix the touch.
Abhimanyu Raj - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 42
전체 시간: 7,212
