주요 콘텐츠로 건너뛰기
How to put your Xbox 360 external HDD into Xbox 360 Slim
필요한 것
동영상 개요
How to dismantle a Xbox 360 external hard drive.
    • Get your old xbox 360 External HDD(Hard Disk Drive)
    • Locate the screws
    • Insert it down into the slots. You should hear a slight click if it has been inserted correctly.
    • I hear Microsoft's warranty support service doesn't take kindly to freely bouncing hard drives.
결론
Cheaper and less hassle than to get a hard drive for the Xbox 360 Slim and transfer data.
다른 3명이 해당 안내서를 완성하였습니다.
Paul
회원 가입일: 08/29/13
207 평판
안내서 1개 작성함
댓글 2개
If you don’t have the metal tray the HDD it secured too you can still insert the hard drive into the new console although it will be suspended by the connector and will bounce around and could easily become dislodged if the console was moved and you hard drive could fall and end up corrupted.
Eye Fix It - 답글
Hence why I put the last part and in red. You must of seen the funny side of it.
Paul -
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 19
30일 전: 97
전체 시간: 7,374
