주요 콘텐츠로 건너뛰기
How to re-caulk a bathroom sink
필요한 것
  1. How to re-caulk a bathroom sink, Caulk seal: 1 단계, 이미지 1개 중 1개
    • Clean and dry around the rim of the sink with a paper towel.
    • Make sure the old caulk is completely dry before moving on.
  2. How to re-caulk a bathroom sink: 2 단계, 이미지 1개 중 1개
    • Remove the old caulk around the rim of the sink with a utility knife.
  3. How to re-caulk a bathroom sink: 3 단계, 이미지 1개 중 1개
    • Remove any old caulk residue around the rim of the sink with a wet paper towel.
    • Then dry the area completely.
    • Ensure the area is completely clean and dry before applying the new caulk.
  4. How to re-caulk a bathroom sink: 4 단계, 이미지 3개 중 1개 How to re-caulk a bathroom sink: 4 단계, 이미지 3개 중 2개 How to re-caulk a bathroom sink: 4 단계, 이미지 3개 중 3개
    • Apply painter's tape around the rim of the sink while leaving a small gap for caulk to be applied.
  5. How to re-caulk a bathroom sink: 5 단계, 이미지 2개 중 1개 How to re-caulk a bathroom sink: 5 단계, 이미지 2개 중 2개
    • Place the caulk tube into the gun.
    • Slowly press the trigger to release a thin line of caulk and move around the edge of the sink as you go.
  6. How to re-caulk a bathroom sink: 6 단계, 이미지 3개 중 1개 How to re-caulk a bathroom sink: 6 단계, 이미지 3개 중 2개 How to re-caulk a bathroom sink: 6 단계, 이미지 3개 중 3개
    • Smooth out the caulk against the edge of the rim and counter with your wet index finger.
    • Keep a rag nearby to wipe excess caulk from your finger periodically.
    • Press against the caulk firmly while sliding your index finger as you go around the rim of the sink.
  7. How to re-caulk a bathroom sink: 7 단계, 이미지 3개 중 1개 How to re-caulk a bathroom sink: 7 단계, 이미지 3개 중 2개 How to re-caulk a bathroom sink: 7 단계, 이미지 3개 중 3개
    • Pull the tape away from the counter immediately after applying the caulk.
    • Pulling away from the counter will help keep the caulk in a straight line.
  8. How to re-caulk a bathroom sink: 8 단계, 이미지 1개 중 1개
    • Wipe off any excess caulk from the edge of the rim with a wet paper towel.
  9. How to re-caulk a bathroom sink: 9 단계, 이미지 1개 중 1개
    • Let the new caulk dry for at least a day before using the sink.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Thi Nguyen
회원 가입일: 04/29/20
201 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G43, Cardinal Spring 2020 UW Tacoma, Team S1-G43, Cardinal Spring 2020 회원
UWT-CARDINAL-S20S1G43
1 회원
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 31
지난 30일: 133
전체 시간: 7,194
