주요 콘텐츠로 건너뛰기
How to realign HP Photosmart D110a scanner
필요한 것
  1. How to realign HP Photosmart D110a scanner, Printer Hood Assembly: 1 단계, 이미지 1개 중 1개
    • Pull down both front panels to open the printer. Lift the scanner flap upward by pulling down on it; there are two mouth pieces that need to be pulled down.
    • Adjust the flap covering the scanner upward, as shown.
  2. How to realign HP Photosmart D110a scanner: 2 단계, 이미지 1개 중 1개
    • Pull the scanner flap gently away from the printer to release its two clips.
  3. How to realign HP Photosmart D110a scanner: 3 단계, 이미지 1개 중 1개
    • Locate the three screws on top of the printer.
    • The orange circle shows a fourth screw located behind the power panel. Ignore this one for now, as directions to remove this screw are in Step 5.
  4. How to realign HP Photosmart D110a scanner: 4 단계, 이미지 3개 중 1개 How to realign HP Photosmart D110a scanner: 4 단계, 이미지 3개 중 2개 How to realign HP Photosmart D110a scanner: 4 단계, 이미지 3개 중 3개
    • Using a T-9 screwdriver, remove the three screws from the printer's top.
  5. How to realign HP Photosmart D110a scanner: 5 단계, 이미지 2개 중 1개 How to realign HP Photosmart D110a scanner: 5 단계, 이미지 2개 중 2개
    • To remove the power button panel:
    • Reach inside the printer's front opening.
    • Press the small clip behind the power button.
    • A picture of the power button panel removed is provided to show the location of the clip that needs to be pressed.
    • Pull the panel out from right to left.
  6. How to realign HP Photosmart D110a scanner: 6 단계, 이미지 2개 중 1개 How to realign HP Photosmart D110a scanner: 6 단계, 이미지 2개 중 2개
    • Remove the fourth screw, which was covered by the power button panel.
    • Do not try and torque the screw from an angle. This will ruin the screw's head, and make it even more difficult to remove the screw. Only remove it as already described.
    • This screw is placed awkwardly. We found holding a T9 bit in a pair of needle nose pliers gave us enough leverage to pull it up.
  7. How to realign HP Photosmart D110a scanner: 7 단계, 이미지 3개 중 1개 How to realign HP Photosmart D110a scanner: 7 단계, 이미지 3개 중 2개 How to realign HP Photosmart D110a scanner: 7 단계, 이미지 3개 중 3개
    • With a partner's help:
    • Have one person lift the hood 2-3 inches.
    • Have the other person disconnect the three cables from the motherboard (the green PCB) to the hood by gently pulling upward on them.
    • Remove the hood completely.
  8. How to realign HP Photosmart D110a scanner, Printer Hood: 8 단계, 이미지 3개 중 1개 How to realign HP Photosmart D110a scanner, Printer Hood: 8 단계, 이미지 3개 중 2개 How to realign HP Photosmart D110a scanner, Printer Hood: 8 단계, 이미지 3개 중 3개
    • Remove the single T-9 screw from the hood's underside, as shown.
  9. How to realign HP Photosmart D110a scanner: 9 단계, 이미지 2개 중 1개 How to realign HP Photosmart D110a scanner: 9 단계, 이미지 2개 중 2개
    • With the screw removed, separate the two pieces of the hood by lifting it vertically.
    • Only lift the the top piece enough so that there is no tension applied to the ribbon cables shown.
    • Carefully pull down the white ribbon cable through the top piece of the hood.
  10. How to realign HP Photosmart D110a scanner: 10 단계, 이미지 2개 중 1개 How to realign HP Photosmart D110a scanner: 10 단계, 이미지 2개 중 2개
    • Separate the hood pieces while keeping the black ribbon cable connected. Rest the scanner piece carefully to avoid stressing its ribbon cable.
  11. How to realign HP Photosmart D110a scanner, How to realign HP Photosmart D110a scanner: 11 단계, 이미지 3개 중 1개 How to realign HP Photosmart D110a scanner, How to realign HP Photosmart D110a scanner: 11 단계, 이미지 3개 중 2개 How to realign HP Photosmart D110a scanner, How to realign HP Photosmart D110a scanner: 11 단계, 이미지 3개 중 3개
    • After having the hood removed and disassembled, locate the scanner.
    • Adjust the scanner wheel such that fits into the path.
    • If the black ribbon cable is twisted, untwist it so it appears as shown.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Tim Wise
회원 가입일: 04/01/11
173 평판
안내서 7개를 작성함
Cal Poly, Team 10-38, Forte Spring 2011 Cal Poly, Team 10-38, Forte Spring 2011 회원
CPSU-FORTE-S11S10G38
5 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 17
전체 시간: 3,502
