이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Take the battery apart and check out what cell you need. This may be difficult depending on the wrap used.
After purchasing a battery, disassemble the CMOS battery. Use caution not to heavily bend the tabs. Too much damage may make them unusable.
Break the tabs off of the old battery. Dispose of based on your local laws.
After the polarity has been matched, tape the positive lead to the new cell. To remove the risk of a failed rebuild, start on the + side and cut the tape to fit comfortably.
After confirming the tape is not causing a short, add tape to the negative tab and tape down the negative terminal onto the new battery.
After verifying both leads are securely held onto the new cell, apply liquid electrical tape to the battery. 2-3 medium thickness coats are recommended.
다른 8명이 해당 안내서를 완성하였습니다.
