주요 콘텐츠로 건너뛰기
How to recover/reupholster WESC Maraca Headphone Ear Cushions
필요한 것
  1. How to recover/reupholster WESC Maraca Headphone Ear Cushions, How to recover/reupholster WESC Maraca Headphone Ear Cushions: 1 단계, 이미지 1/3 How to recover/reupholster WESC Maraca Headphone Ear Cushions, How to recover/reupholster WESC Maraca Headphone Ear Cushions: 1 단계, 이미지 2/3 How to recover/reupholster WESC Maraca Headphone Ear Cushions, How to recover/reupholster WESC Maraca Headphone Ear Cushions: 1 단계, 이미지 3/3
    • Remove the cushion from the headphones by carefully pushing the edges out from the sides of the ear piece.
  2. How to recover/reupholster WESC Maraca Headphone Ear Cushions: 2 단계, 이미지 1/3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: 2 단계, 이미지 2/3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: 2 단계, 이미지 3/3
    • Use a marker to draw an arrow shape around the bottom of the cushion.
    • The arrow's point should fall toward the center of the cushion.
    • The points on the sides of the arrow should extend well beyond the edge of the cushion. They should not be aligned with the corners of the cushion.
    • This is done to ensure that there will be enough fabric to sufficiently cover the cushion.
    • The bottom of the arrow should line up with the sides and bottom of the cushion.
    • Repeat this step to draw a wider arrow for the side of the cushion.
  3. How to recover/reupholster WESC Maraca Headphone Ear Cushions: 3 단계, 이미지 1/2 How to recover/reupholster WESC Maraca Headphone Ear Cushions: 3 단계, 이미지 2/2
    • Cut out the two arrows of fabric.
    • Using the arrows as guides, cut out 3 additional arrows of each different size. In total you will have 4 top and bottom arrows and 4 side arrows.
  4. How to recover/reupholster WESC Maraca Headphone Ear Cushions: 4 단계, 이미지 1/3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: 4 단계, 이미지 2/3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: 4 단계, 이미지 3/3
    • Attach the tip of the arrow to the inside of the cushion and fold the rest of the arrow over the outside.
    • Using glue or sewing the arrow to the pad will result in a permanent fix, but if you make a mistake you may not be able to undo it.
    • Repeat this step to attach each arrow to the appropriate side of each cushion
  5. How to recover/reupholster WESC Maraca Headphone Ear Cushions: 5 단계, 이미지 1/3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: 5 단계, 이미지 2/3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: 5 단계, 이미지 3/3
    • Once you have all of the fabric attached, stretch the edges of the cushion back over the headphone's ear piece.
    • Use a thin plastic card to carefully tuck the edges of the cushion back into the ear piece.
  6. How to recover/reupholster WESC Maraca Headphone Ear Cushions: 6 단계, 이미지 1/3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: 6 단계, 이미지 2/3 How to recover/reupholster WESC Maraca Headphone Ear Cushions: 6 단계, 이미지 3/3
    • Once the cushion has been reattached to the ear piece, use the plastic card to carefully tuck the bottoms of the fabric arrows into the sides of the ear piece.
    • If there is too much fabric to tuck in, use scissors to remove the excess.
결론
Your headphones are now reupholstered and ready to use again.
다른 5명이 해당 안내서를 완성하였습니다.
rss
회원 가입일: 02/24/15
265 평판
안내서 1개 작성함
Cal Poly, Team 24-1, Green Winter 2015 Cal Poly, Team 24-1, Green Winter 2015 회원
CPSU-GREEN-W15S24G1
4 회원들
안내서 4개 작성하였습니다
One Comment
thanks for the idea! but I have to say this was a lot harder & less successful than promised, I’ve been at it for 1 hour and have only “reupholstered” 1 earphone… and it’s very partial (has holes). I rate my fixing result at 3/10, and I followed the instructions. :(
GYD - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 63
30일 전: 246
전체 시간: 12,251
