이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
It is time to do a wheel distribution if you notice that your skates are less balanced, stop poorly, and that your wheels are not symmetrical. Wheel distribution is a free alternative to buying a brand new set of wheels, and an important part of basic skate maintenance.
필요한 것
Set up the skates on a surface that is okay to get a little messy.
The wheels shown in the third photo are very heavily worn. It may be best to simply replace the wheels at this point.
All wheels should spin freely. Adding the wheels back into the frame are trickier than getting them out and play a bigger role in your personal safety, so make sure to do that final check. Hopefully, the redistributed wheels will bring back some life into your old skates!
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 3개
do you fix vive headset
vive headset strap. snap on
I can get one side of the bolts off but not the other side. They just keep spinning when I try to loosen them. Any ideas on how to get the rest of the bolts out?
Cat Graham - 답글
