주요 콘텐츠로 건너뛰기
How to refurbish performance skateboard bearings
필요한 것
  1. How to refurbish performance skateboard bearings, How to refurbish performance skateboard bearings: 1 단계, 이미지 2개 중 1개 How to refurbish performance skateboard bearings, How to refurbish performance skateboard bearings: 1 단계, 이미지 2개 중 2개
    • Turn your wrench to the left to remove the wheel nut.
    • Take the wheel off of your trucks by pulling.
    • Keep all nuts and spacers in separated, designated areas.
    • Wear gloves. You are working with messy materials such as gasoline.
  2. How to refurbish performance skateboard bearings: 2 단계, 이미지 2개 중 1개 How to refurbish performance skateboard bearings: 2 단계, 이미지 2개 중 2개
    • Firmly lever the bearing out using your screwdriver.
    • Do not be overly forceful to avoid scratching the bearing.
  3. How to refurbish performance skateboard bearings: 3 단계, 이미지 1개 중 1개
    • Soak the bearing in a cup with premium gasoline for 5 minutes.
    • Soak each bearing separately so none are lost or dented.
  4. How to refurbish performance skateboard bearings: 4 단계, 이미지 3개 중 1개 How to refurbish performance skateboard bearings: 4 단계, 이미지 3개 중 2개 How to refurbish performance skateboard bearings: 4 단계, 이미지 3개 중 3개
    • Take the bearing out of the gasoline and remove one side of the outside plastic locks by applying pressure on the inner ring and prying up.
    • Make sure you can clearly see and access the ball bearings.
  5. How to refurbish performance skateboard bearings: 5 단계, 이미지 1개 중 1개
    • Use your toothbrush to clean the bearings by using a gentle back and forth scrubbing motion.
    • Rinse the bearing with water and let dry for 5 minutes.
  6. How to refurbish performance skateboard bearings: 6 단계, 이미지 2개 중 1개 How to refurbish performance skateboard bearings: 6 단계, 이미지 2개 중 2개
    • Once dry, pick up your bearings with two fingers and drop 2 drops of skateboard lubricant into the bearing.
    • Spin the bearings immediately to spread the lubricant evenly.
  7. How to refurbish performance skateboard bearings: 7 단계, 이미지 3개 중 1개 How to refurbish performance skateboard bearings: 7 단계, 이미지 3개 중 2개 How to refurbish performance skateboard bearings: 7 단계, 이미지 3개 중 3개
    • Use a paper towel to remove excess lubricant.
    • Replace the plastic guard.
결론
To reassemble your device, firmly put bearings back into your wheels and tighten them back down onto the trucks.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Luke Marshall
회원 가입일: 04/09/15
126 평판
안내서 1개를 작성함
Cal Poly, Team 30-2, Green Spring 2015 Cal Poly, Team 30-2, Green Spring 2015 회원
CPSU-GREEN-S15S30G2
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 7
전체 시간: 6,076
