소개
Before starting this guide there are some things you should be aware of; First make sure your vehicle is parked on a level surface with the parking brake on. This is needed for one step so you can safely put the vehicle in 1st gear so the shifter is out of the way. For this tutorial the only tools needed are 1/4" ratchet, 16mm wrench, and 7 mm wrench .
필요한 것
Locate the hood latch in your vehicle found on the drivers side under the dashboard to the left of the parking brake pedal.
Pull the latch to release hood.
Place the head unit face down to allow the wires on the back to be visible and more easily accessible.
Listed below are the wires coming connected to the head unit. The colors correspond to the same color of the wire.
RCA inputs
Microphone input/wire
Power/audio/assorted control wire harness
Antenna input/wire
Harness disconnect
다른 9명이 해당 안내서를 완성하였습니다.
