주요 콘텐츠로 건너뛰기
How to remove a stuck bike seat post without destroying the post
필요한 것
동영상 개요
  1. How to remove a stuck bike seat post without destroying the post, How to remove a stuck bike seat post without destroying the post: 1 단계, 이미지 1개 중 1개
    • For Tools you will need a saw, socket set, drill, wire brush drill bit that inside the post sleeve and a long drill bit extension.
    • For parts you will need about a foot of stout chain, two quick links, 1/4" #8 steel bolt/washers/nut long enough to go through the seat post, two 1/4" steel bolts/washers/nuts at least 5 1/2" long to hold the 2x4s together at the base and a huge eye bolt and a 8' 2x4 stud. all can be bought at your local hardware store.
    • Look for a rating of at least 1000lb in all the parts you buy. they are low cost and that way you don't need to worry about things snapping.
    • cut a 5" section of 2x4 and drill a hole in the middle for the eye bolt.
결론
작성자
3다른 기여자 명과 함께
Gabe
회원 가입일: 01/28/15
318 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 33
전체 시간: 2,749
