주요 콘텐츠로 건너뛰기
How to remove and clean Arbor Rally Longboard bearings
필요한 것
  1. How to remove and clean Arbor Rally Longboard bearings, How to remove and clean Arbor Rally Longboard bearings: 1 단계, 이미지 2개 중 1개 How to remove and clean Arbor Rally Longboard bearings, How to remove and clean Arbor Rally Longboard bearings: 1 단계, 이미지 2개 중 2개
    • Use the half inch wrench to remove the nut on each wheel. Then remove each wheel.
    • Be careful not to lose the washers that sit between the nut and wheel, they are small and hard to find after you lose them.
  2. How to remove and clean Arbor Rally Longboard bearings: 2 단계, 이미지 3개 중 1개 How to remove and clean Arbor Rally Longboard bearings: 2 단계, 이미지 3개 중 2개 How to remove and clean Arbor Rally Longboard bearings: 2 단계, 이미지 3개 중 3개
    • Use needle nose pliers to remove the bearings from both sides of each wheel.
  3. How to remove and clean Arbor Rally Longboard bearings: 3 단계, 이미지 2개 중 1개 How to remove and clean Arbor Rally Longboard bearings: 3 단계, 이미지 2개 중 2개
    • Place the bearings in soapy water and let them soak for 5 minutes.
  4. How to remove and clean Arbor Rally Longboard bearings: 4 단계, 이미지 3개 중 1개 How to remove and clean Arbor Rally Longboard bearings: 4 단계, 이미지 3개 중 2개 How to remove and clean Arbor Rally Longboard bearings: 4 단계, 이미지 3개 중 3개
    • Wipe off the dirt from each bearing and dry them thoroughly with a paper towel.
  5. How to remove and clean Arbor Rally Longboard bearings: 5 단계, 이미지 2개 중 1개 How to remove and clean Arbor Rally Longboard bearings: 5 단계, 이미지 2개 중 2개
    • Apply a few drops of lubricant to the inner portion on both sides of each bearing.
    • Spin the bearings and wipe off any extra lubricant that has not settled in.
  6. How to remove and clean Arbor Rally Longboard bearings: 6 단계, 이미지 3개 중 1개 How to remove and clean Arbor Rally Longboard bearings: 6 단계, 이미지 3개 중 2개 How to remove and clean Arbor Rally Longboard bearings: 6 단계, 이미지 3개 중 3개
    • Push the bearing into the wheel by applying even pressure with your thumb.
  7. How to remove and clean Arbor Rally Longboard bearings: 7 단계, 이미지 3개 중 1개 How to remove and clean Arbor Rally Longboard bearings: 7 단계, 이미지 3개 중 2개 How to remove and clean Arbor Rally Longboard bearings: 7 단계, 이미지 3개 중 3개
    • Spin the wheel to make sure that the bearings are properly aligned and running smoothly.
  8. How to remove and clean Arbor Rally Longboard bearings: 8 단계, 이미지 3개 중 1개 How to remove and clean Arbor Rally Longboard bearings: 8 단계, 이미지 3개 중 2개 How to remove and clean Arbor Rally Longboard bearings: 8 단계, 이미지 3개 중 3개
    • Place the wheel on the axle followed by washer and then the nut.
    • Tighten the nut with your fingers as much as you can first and then use the wrench to finish the job.
    • Do not tighten the nut too much or else the wheel will not be able to spin. You should be able to slightly shake the wheel up and down along the axle.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Casey Barbello
회원 가입일: 07/24/13
187 평판
안내서 1개를 작성함
댓글 2개
Great guide! I was trying to figure out how to pop the bearings out - the needle nose pliers did a great job.
jewbot007 - 답글
It is usual practice to clean bearings with alcohol or a citrus cleaner; the latter is safer but more likely to leave residues. Since a citrus cleaning is water-based, you must quickly dry your bearings in order to prevent rust.
Mark Daniels - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 1
전체 시간: 12,900
