주요 콘텐츠로 건너뛰기
How to remove and clean iRobot Roomba 655 Pet Series brushes
  1. How to remove and clean iRobot Roomba 655 Pet Series brushes, How to remove and clean iRobot Roomba 655 Pet Series brushes: 1 단계, 이미지 1/3 How to remove and clean iRobot Roomba 655 Pet Series brushes, How to remove and clean iRobot Roomba 655 Pet Series brushes: 1 단계, 이미지 2/3 How to remove and clean iRobot Roomba 655 Pet Series brushes, How to remove and clean iRobot Roomba 655 Pet Series brushes: 1 단계, 이미지 3/3
    • Push down on the two yellow tabs, and pull open the brush gate gently
  2. How to remove and clean iRobot Roomba 655 Pet Series brushes, Removing The Brushes: 2 단계, 이미지 1/3 How to remove and clean iRobot Roomba 655 Pet Series brushes, Removing The Brushes: 2 단계, 이미지 2/3 How to remove and clean iRobot Roomba 655 Pet Series brushes, Removing The Brushes: 2 단계, 이미지 3/3
    • Grab and pull up on the brushes to remove them
    • Use a damp microfiber or terry cloth to clean the rubber brush
  3. How to remove and clean iRobot Roomba 655 Pet Series brushes, Cleaning the Bristle Brush: 3 단계, 이미지 1/3 How to remove and clean iRobot Roomba 655 Pet Series brushes, Cleaning the Bristle Brush: 3 단계, 이미지 2/3 How to remove and clean iRobot Roomba 655 Pet Series brushes, Cleaning the Bristle Brush: 3 단계, 이미지 3/3
    • Use the included hair cutter to cut through hair that has gotten caught in the brush
    • Slide the brush cleaner down and back up until your brush is clean
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matt Davis
회원 가입일: 01/22/15
1,612 평판
안내서 7개 작성하였습니다
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 회원
CPSU-MANESS-W15S21G20
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
My little yellow brushes are not sweeping(turning). What can I do?
fourbronco2 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 23
전체 시간: 3,099
