소개
It is recommended to clean your Roomba every week (depending on how often you use it).
Push down on the two yellow tabs, and pull open the brush gate gently
이 단계에 사용된 도구:Microfiber Cleaning Cloths$3.99
Grab and pull up on the brushes to remove them
Use a damp microfiber or terry cloth to clean the rubber brush
Use the included hair cutter to cut through hair that has gotten caught in the brush
Slide the brush cleaner down and back up until your brush is clean
다른 2명이 해당 안내서를 완성하였습니다.
