주요 콘텐츠로 건너뛰기
How to remove burnt stains on pans
필요한 것
  1. How to remove burnt stains on pans, How to remove burnt stains on pans: 1 단계, 이미지 2개 중 1개 How to remove burnt stains on pans, How to remove burnt stains on pans: 1 단계, 이미지 2개 중 2개
    • Prepare your workstation by making sure you have all the listed tools. Next, ensure the burnt pan is cool before starting the process. Remove any loose debris or food particles from the pan.
  2. How to remove burnt stains on pans, Baking Soda Application: 2 단계, 이미지 2개 중 1개 How to remove burnt stains on pans, Baking Soda Application: 2 단계, 이미지 2개 중 2개
    • Sprinkle a generous amount of baking soda over the burnt areas of the pan. Use enough baking soda to cover the stains fully.
  3. How to remove burnt stains on pans: 3 단계, 이미지 1개 중 1개
    • Sprinkle salt over the baking soda. Salt acts as an abrasive agent and enhances the cleaning process.
  4. How to remove burnt stains on pans: 4 단계, 이미지 2개 중 1개 How to remove burnt stains on pans: 4 단계, 이미지 2개 중 2개
    • Pour white vinegar over the baking soda and salt mixture. The vinegar will react with the baking soda, creating a foaming action that helps loosen the burnt stains.
  5. How to remove burnt stains on pans: 5 단계, 이미지 2개 중 1개 How to remove burnt stains on pans: 5 단계, 이미지 2개 중 2개
    • Place the pan on a stove or heat source. Heat the pan on low to medium heat for 5-10 minutes. Ensure to use your phone or a timer . The heat helps activate the cleaning ingredients and loosen the burnt stains.
  6. How to remove burnt stains on pans: 6 단계, 이미지 3개 중 1개 How to remove burnt stains on pans: 6 단계, 이미지 3개 중 2개 How to remove burnt stains on pans: 6 단계, 이미지 3개 중 3개
    • After heating, allow the pan to cool slightly for 6 minutes . Make sure to wear rubber gloves, and gently scrub the burnt areas with a soft sponge or scrubbing brush. Continue cleaning until the burnt stains start to lift off.
  7. How to remove burnt stains on pans: 7 단계, 이미지 2개 중 1개 How to remove burnt stains on pans: 7 단계, 이미지 2개 중 2개
    • Rinse the pan thoroughly with cold water to remove any remaining baking soda, salt, and vinegar residue. Repeat the process for stubborn stains until the pan is clean.
  8. How to remove burnt stains on pans: 8 단계, 이미지 1개 중 1개
    • Stained Pan looking fresh as New !
결론
To remove stains from your cooking pan, follow these step by step instructions.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alessia Maneli
회원 가입일: 02/08/24
184 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 185
