주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to remove scratches from an Airpods Case
필요한 것
  1. How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: 1 단계, 이미지 2개 중 1개 How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: 1 단계, 이미지 2개 중 2개
    • The front and back are already scarred.
  2. How to remove scratches from an Airpods Case: 2 단계, 이미지 1개 중 1개
    • Use 2000 grit and above fine-grained sandpaper.
    • For this tutorial, I used 2500 grit directly and then 3000 grit for a finer finish.
    • Careful when choosing a grit, a too coarse sandpaper grit will damage the airpods case
  3. How to remove scratches from an Airpods Case: 3 단계, 이미지 1개 중 1개
    • Cotton wool and medical alcohol are used to clean the surface of the charging case.
  4. How to remove scratches from an Airpods Case: 4 단계, 이미지 2개 중 1개 How to remove scratches from an Airpods Case: 4 단계, 이미지 2개 중 2개
    • Clean the surface of the charging case with absorbent cotton dipped in alcohol.
    • Clean up the inside too!
  5. How to remove scratches from an Airpods Case: 5 단계, 이미지 1개 중 1개
    • Wet the surface with absorbent cotton or a little water, and then lightly sand it with 2500-grit fine sandpaper.
    • It can be seen that the more serious scratches have been smoothed out, the polished areas have turned white, and the smooth surface has become matte.
    • This step can be performed as many times as necessary.
  6. How to remove scratches from an Airpods Case: 6 단계, 이미지 1개 중 1개
    • It has now returned to white, but the surface is still matte.
    • If you like this matte style, you can stop
    • To restore a smooth surface, continue sanding with 3000 grit sandpaper in the same way as in the previous step.
    • The finer the sandpaper, the smoother it will be.
  7. How to remove scratches from an Airpods Case: 7 단계, 이미지 1개 중 1개
    • Refreshed now!
결론
This will give the charging case a refreshed look instead of a dirty, scratched surface.
다른 31명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
zh en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Z.Heng
회원 가입일: 04/08/17
3,862 평판
안내서 3개를 작성함
8가이드 댓글
Extremely convincing, especially the last picture.
Ludger - 답글 공유
感谢作者!我的AirPods也布满了划痕!
Zhang Boyang - 답글 공유
Kann man auch Polierpaste nutzen wie sie für Kunststoffdisplays benutzt wird?
neo1983-jahn - 답글 공유
How big can the scratches be ?
Albert zweisteim - 답글 공유
How do you get it shiny again?
lucas cheraki - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 130
지난 30일: 482
전체 시간: 94,469
