소개
Just a quick demonstration of how the rear view mirror un-mounts from the windshield.
This is a 2006 Hyundai Santa Fe
To reinstall you need to remove the plastic mount cover, then just slide the assembly back into the mount, and reinstall the cover.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Our mirror (2004) has a screw from the windshield mount pointing back into the mirror (?). How do I get this screw installed again with the button glued to the glass?
Got it figured out. The part with the screw is the bracket that slides downward. I inserted a screwdriver and tapped it with a hammer to slide it out. From there I was able to screw the two back together and fit it back into the windshield.
