주요 콘텐츠로 건너뛰기
How to remove the 2010-2017 Suzuki Swift air intake box
필요한 것
  1. How to remove the 2010-2017 Suzuki Swift air intake box, Loosen the air intake box: 1 단계, 이미지 1/3 How to remove the 2010-2017 Suzuki Swift air intake box, Loosen the air intake box: 1 단계, 이미지 2/3 How to remove the 2010-2017 Suzuki Swift air intake box, Loosen the air intake box: 1 단계, 이미지 3/3
    • Unscrew the 10mm bolts.
    • Remove the push rivet with the flathead.
    • Unclip the cable from the bracket. Use the plyers to press the lock from beneath and pull the clip loose.
    • Pull back the clasps connecting the air intake box to the rest of the intake system.
  2. How to remove the 2010-2017 Suzuki Swift air intake box, Remove the air intake box: 2 단계, 이미지 1/3 How to remove the 2010-2017 Suzuki Swift air intake box, Remove the air intake box: 2 단계, 이미지 2/3 How to remove the 2010-2017 Suzuki Swift air intake box, Remove the air intake box: 2 단계, 이미지 3/3
    • Grab the box at the left side and pull up and towards the right to pull the top part of air intake box out.
    • Pull the intake pipe up and out.
결론
To reassemble, follow these instructions in reverse order.
knipwim
회원 가입일: 09/01/18
8,517 평판
안내서 30개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 31
30일 전: 86
전체 시간: 2,094
