주요 콘텐츠로 건너뛰기
How to remove the 2010-2017 Suzuki Swift front bumper
필요한 것
  1. How to remove the 2010-2017 Suzuki Swift front bumper, remove the top fasteners: 1 단계, 이미지 1/3 How to remove the 2010-2017 Suzuki Swift front bumper, remove the top fasteners: 1 단계, 이미지 2/3 How to remove the 2010-2017 Suzuki Swift front bumper, remove the top fasteners: 1 단계, 이미지 3/3
    • Open the hood and unscrew the 10mm bolts located at the top.
    • Unscrew the screw located at the side top corner under the fender, repeat on the other side.
  2. How to remove the 2010-2017 Suzuki Swift front bumper, remove bottom fasteners: 2 단계, 이미지 1/3 How to remove the 2010-2017 Suzuki Swift front bumper, remove bottom fasteners: 2 단계, 이미지 2/3 How to remove the 2010-2017 Suzuki Swift front bumper, remove bottom fasteners: 2 단계, 이미지 3/3
    • Unscrew 4 screws located underneath the front of the front bumper.
    • With the flathead, unclip the 2 push rivets underneath the side of the front bumper, disconnecting each fender from the bumper.
    • Repeat on the other side.
  3. How to remove the 2010-2017 Suzuki Swift front bumper, detach top corners: 3 단계, 이미지 1/2 How to remove the 2010-2017 Suzuki Swift front bumper, detach top corners: 3 단계, 이미지 2/2
    • Gently, pull the side corner loose.
    • Pull from the car and slightly downwards to detach the remaining corner.
  4. How to remove the 2010-2017 Suzuki Swift front bumper, unlatch the bumper: 4 단계, 이미지 1/2 How to remove the 2010-2017 Suzuki Swift front bumper, unlatch the bumper: 4 단계, 이미지 2/2
    • If your car has fog lights, make sure you disconnect them from the car's wiring.
    • The bumper is now only attached with 2 clips at the top.
    • Push the front of each clip towards the car and unlatch it.
  5. How to remove the 2010-2017 Suzuki Swift front bumper, remove the bumper: 5 단계, 이미지 1/3 How to remove the 2010-2017 Suzuki Swift front bumper, remove the bumper: 5 단계, 이미지 2/3 How to remove the 2010-2017 Suzuki Swift front bumper, remove the bumper: 5 단계, 이미지 3/3
    • Hold the bumper in the center and remove it by moving it down and outwards.
    • The bumper wraps around the bottom and fender parts, take care not to damage anything when removing the bumper.
    • Some of the 4 bottom nut clips might move or detach entirely when removing the bumper. Ensure these are at their correct positions.
결론
다른 2명이 해당 안내서를 완성하였습니다.
knipwim
회원 가입일: 09/01/18
8,527 평판
안내서 30개 작성하였습니다
댓글 3개
In mine there were also two screws at the corners featured in step 3 that needed removing.
Thomas Bell - 답글
Other screws than you need to remove in step 1 photo 2/3?
knipwim -
Followoing your instruction on Step 3. I break 3 small clips that attach the bumper on the side. Now without the 3 clips, my bumper looks a bit overhang from the side
Mr Ismail Harun - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 42
30일 전: 198
전체 시간: 6,058
