주요 콘텐츠로 건너뛰기
How to remove the Samsung LA40R81BD 40in LCD TV rear cover
필요한 것
  1. How to remove the Samsung LA40R81BD 40in LCD TV rear cover, Rear Cover: 1 단계, 이미지 1/1
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Richdave
회원 가입일: 04/09/10
32,287 평판
안내서 30개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,525개 작성하였습니다
댓글 3개
Got cover off but how to unplug the wires
cpeeledc - 답글
What size screws holds on the rear panel?
D Mack Miller - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 40
전체 시간: 24,260
