주요 콘텐츠로 건너뛰기
How to remove the back cover of the LG Extravert
필요한 것
  1. How to remove the back cover of the LG Extravert, Flip over phone: 1 단계, 이미지 2개 중 1개 How to remove the back cover of the LG Extravert, Flip over phone: 1 단계, 이미지 2개 중 2개
    • Start by flipping over the phone
  2. How to remove the back cover of the LG Extravert, Remove cover: 2 단계, 이미지 2개 중 1개 How to remove the back cover of the LG Extravert, Remove cover: 2 단계, 이미지 2개 중 2개
    • Remove the case on the back of the cell phone by pulling up on the little indent with your fingernail or a Spudger in the bottom of the phone.
  3. How to remove the back cover of the LG Extravert, Remove battery: 3 단계, 이미지 3개 중 1개 How to remove the back cover of the LG Extravert, Remove battery: 3 단계, 이미지 3개 중 2개 How to remove the back cover of the LG Extravert, Remove battery: 3 단계, 이미지 3개 중 3개
    • After you pull off the case, the battery is right under it. All you have to do is put you Spudger or fingernail into the indent on the right side of the battery and pull up.
  4. How to remove the back cover of the LG Extravert, Removing Screws: 4 단계, 이미지 1개 중 1개
    • Using a JIS #000 screwdriver, remove all 8 screws.
  5. How to remove the back cover of the LG Extravert, Remove the black cover.: 5 단계, 이미지 1개 중 1개
    • Using the Ifixit Opening Tool, insert it near the small indent, sliding it to the right. then pull towards the outside of the phone.
    • Be careful, as the Antennas are under the cover.
  6. How to remove the back cover of the LG Extravert, Start removing the case: 6 단계, 이미지 1개 중 1개
    • slide out the keyboard.
    • put your ring finger on the red rim around the keyboard, and your thumb on the model label.
    • push away from the phone with your index finger, and towards the phone with your thumb. there should be a small pop sound, as the casing will slightly pull from the phone.
  7. How to remove the back cover of the LG Extravert, Opening the left side: 7 단계, 이미지 1개 중 1개
    • insert a opening pick or a Ifixit opening tool into the gap your created in the last step, moving to the left.
  8. How to remove the back cover of the LG Extravert, Opening the top: 8 단계, 이미지 1개 중 1개
    • Please note this side is the most difficult due to the camera bulge.
    • insert the opening pick or Ifixit opening tool into the top left corner, and move upwards.
    • The right side should pop open most of the way when you get near the headphone jack
  9. How to remove the back cover of the LG Extravert, Opening the bottom: 9 단계, 이미지 2개 중 1개 How to remove the back cover of the LG Extravert, Opening the bottom: 9 단계, 이미지 2개 중 2개
    • Turn the phone onto its backside.
    • You should be able to pull the case away, but if you can't still, insert your opening pick or ifixit opening tool into the bottom of the battery slot. Slide your tool to the right.
    • Be careful! The antenna could possibly be damaged by a harsh movement.
결론
작성자
1다른 기여자 명과 함께
timtom77
회원 가입일: 11/01/22
3,182 평판
안내서 2개를 작성함
Kid fixers Kid fixers 회원
Community
203 회원들
안내서 288개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 217
