주요 콘텐츠로 건너뛰기
How to remove top vent of Winix C535
필요한 것
  1. How to remove top vent of Winix C535, Locating the tabs: 1 단계, 이미지 1개 중 1개
    • I suggest starting from the middle, popping it out just a tiny bit and move outwards to the sides
    • Apply a small constant lift should make removing this easier. Similar to disassembling other plastic encasements.
  2. How to remove top vent of Winix C535, Taking it out: 2 단계, 이미지 2개 중 1개 How to remove top vent of Winix C535, Taking it out: 2 단계, 이미지 2개 중 2개
    • It pulls towards you a little bit to loosen up and then comes out by moving it forward once it's in this position.
    • Clean the vent and reassemble by inserting it from the bottom first and then clicking in the tabs in the front.
  3. How to remove top vent of Winix C535, Done: 3 단계, 이미지 1개 중 1개
    • Well that was easy wasn't it? Back to making it eat wildfire smoke and whatnot when the time comes.
    • Also do keep in mind that "PlasmaWave" is an ionizing tech which creates ozone in small amounts (regardless of what manufacturer says), so don't use it that often. If you do, you need to air out the room/house when the outside air is cleaner.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Ray
회원 가입일: 01/21/21
127 평판
안내서 1개를 작성함
1가이드 댓글
thank you very much
Thusy Veeram - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 54
전체 시간: 2,091
