주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to renew thermal pads
필요한 것
  1. How to renew thermal pads, locate the thermal pads: 1 단계, 이미지 3개 중 1개 How to renew thermal pads, locate the thermal pads: 1 단계, 이미지 3개 중 2개 How to renew thermal pads, locate the thermal pads: 1 단계, 이미지 3개 중 3개
    • First you want to see how many thermal pads there are and locate their position.
    • The pads may either stick to the frame, the motherboard or broke in two.
    • Remember, you just need to place new pads on either the motherboard or the frame.
    • On some frames there may be markings giving you also an idea of the size and position for the new pads.
  2. How to renew thermal pads, cutting the new pads: 2 단계, 이미지 3개 중 1개 How to renew thermal pads, cutting the new pads: 2 단계, 이미지 3개 중 2개 How to renew thermal pads, cutting the new pads: 2 단계, 이미지 3개 중 3개
    • Grab your new piece of thermal pad and cut it to the sizes you need using a pair of scissors.
    • Some residue might cover a larger area than the marking which is due to the fact that the thermal pad will be squished down flat. In this case stick to the size of the marking for the new pad not the size of the residue.
  3. How to renew thermal pads, cleaning the frame: 3 단계, 이미지 3개 중 1개 How to renew thermal pads, cleaning the frame: 3 단계, 이미지 3개 중 2개 How to renew thermal pads, cleaning the frame: 3 단계, 이미지 3개 중 3개
    • If you are replacing an entire frame (e.g. in a display assembly with frame guide) you can skip this step since your new part should be clean.
    • Scrape off the old thermal pads with an opening tool or a spudger.
    • If you want to go the extra mile you can clean the rest with a Q-tip and some isopropyl alcohol (>97%).
  4. How to renew thermal pads, cleaning the motherboard: 4 단계, 이미지 3개 중 1개 How to renew thermal pads, cleaning the motherboard: 4 단계, 이미지 3개 중 2개 How to renew thermal pads, cleaning the motherboard: 4 단계, 이미지 3개 중 3개
    • Carefully scrape off the thermal pads and the remains with an opening tool or a spudger.
    • Apply only little pressure to not damage any components on the motherboard in case you might slip with the tool. Also make sure you do not press the thermal pads in between small components as it is very cumbersome to get them out afterwards.
    • You might want to clean any remaining residue with a Q-tip and some isopropyl alcohol (>97%).
    • Be sure to only dab on the small components so the fibers of the Q-tip won't get caught.
  5. How to renew thermal pads, apply new thermal pads: 5 단계, 이미지 3개 중 1개 How to renew thermal pads, apply new thermal pads: 5 단계, 이미지 3개 중 2개 How to renew thermal pads, apply new thermal pads: 5 단계, 이미지 3개 중 3개
    • Repeat for every thermal pad:
    • Remove the film from one side of the thermal pad.
    • Place the thermal pad on the frame and press it down a little to make sure it sticks.
    • Remove the remaining film from the thermal pad.
  6. How to renew thermal pads: 6 단계, 이미지 1개 중 1개
    • When you have placed every thermal pad and removed the top film you can reassemble your device.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
133,537 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 71
지난 30일: 327
전체 시간: 19,961
