이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
First you want to see how many thermal pads there are and locate their position.
The pads may either stick to the frame, the motherboard or broke in two.
On some frames there may be markings giving you also an idea of the size and position for the new pads.
Grab your new piece of thermal pad and cut it to the sizes you need using a pair of scissors.
Scrape off the old thermal pads with an opening tool or a spudger.
If you want to go the extra mile you can clean the rest with a Q-tip and some isopropyl alcohol (>97%).
Carefully scrape off the thermal pads and the remains with an opening tool or a spudger.
You might want to clean any remaining residue with a Q-tip and some isopropyl alcohol (>97%).
Repeat for every thermal pad:
Remove the film from one side of the thermal pad.
Place the thermal pad on the frame and press it down a little to make sure it sticks.
Remove the remaining film from the thermal pad.
When you have placed every thermal pad and removed the top film you can reassemble your device.
다른 5명이 해당 안내서를 완성하였습니다.
