주요 콘텐츠로 건너뛰기
How to repair LG G5 Power button ?
필요한 것
동영상 지침
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Witrigs
회원 가입일: 11/24/15
70,190 평판
안내서 377개를 작성함
댓글 12개
Does this cover the power button not functioning? The fingerprint but is vibrating but wont turn the phone on?
mrs_johnson79 - 답글
My power button had been working only intermittently and then almost not at all. The solution was amazingly simple. I wet a Qtip with alcohol and rolled it around the edges of the button, pushing in as much as I could. Each time I did that the button started working better and better. Now it works perfectly. I think between humidity, finger oil and dust, it just got dirty inside.
Simintov - 답글
This alcohol qtip comment helped. Button works again!
Sarah Young - 답글
I had the same problem with my LG G5.  I was very skeptical about the alcohol qtip idea but was all out of ideas and decided to give it a try.  After rubbing it with the qtip for about 5 seconds the button started to work again.  Unbelievable!  Thanks for the great tip.
Craig Meyer - 답글
Well %#*@. The alcohol and q-tip trick worked! I’m floored. I’ve been double-tapping since two months after I got the phone. I used cleaning alcohol, like that for wounds (70%), and pressed the button in with the saturated q-tip while scrubbing around and on the edge. As the above comments mentioned, repetition resulted in increased success: I used a total of one and a half q-tips, and applied alcohol about 3 or 4 times. No disassembly required.
Alexandra Ramsey - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 32,585
