주요 콘텐츠로 건너뛰기
How to repair a Snag in Knit Clothing
필요한 것
  1. How to repair a Snag in Knit Clothing, How to repair a Snag in Knit Clothing: 1 단계, 이미지 1개 중 1개
    • Pull a stringed needle through the loop of the snag.
  2. How to repair a Snag in Knit Clothing: 2 단계, 이미지 1개 중 1개
    • Tie a knot at the end of the snag loop.
  3. How to repair a Snag in Knit Clothing: 3 단계, 이미지 1개 중 1개
    • Put the needle at the base of the snag.
    • Push the needle through the base to the other side.
  4. How to repair a Snag in Knit Clothing: 4 단계, 이미지 1개 중 1개
    • Flip your clothing item over or inside out to see where the needle was pushed through.
    • Pull the needle all the way through. You want it tight enough that you have the whole snag through, but not tight enough to start pulling through more of the clothing item.
  5. How to repair a Snag in Knit Clothing: 5 단계, 이미지 1개 중 1개
    • Tie a knot at the base of the snag.
    • Remember: This is is after you pushed the thread to the inside of your clothing. This pushed the snag to the inside. On the inside snag is where you're tying the new knot where it is coming through.
    • Double knot it for extra security.
  6. How to repair a Snag in Knit Clothing: 6 단계, 이미지 1개 중 1개
    • Cut the extra snag and thread off, leaving a little string near the knot. This leaves a little "tail". Do not cut off the knot or "tail".
    • The small knot and "tail" makes sure the snag doesn't pull through again. If cut, it could unravel the clothing item.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Samantha Bolduc
회원 가입일: 10/27/15
203 평판
안내서 1개를 작성함
Missouri Western, Team 1-1, Adkins Fall 2015 Missouri Western, Team 1-1, Adkins Fall 2015 회원
MWSU-ADKINS-F15S1G1
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 25
전체 시간: 3,472
