주요 콘텐츠로 건너뛰기
How to repair a Tipp-Ex Pocket Mouse 10m
필요한 것
  1. How to repair a Tipp-Ex Pocket Mouse 10m, Opening the housing: 1 단계, 이미지 1개 중 1개
    • Open the red tab at the top of the housing or pull it off.
    • Use a screwdriver to carefully open the housing. Be careful not to use too much force so as not to damage the plastic or the pins.
    • Remove the top of the housing to expose the inner workings of the mouse.
  2. How to repair a Tipp-Ex Pocket Mouse 10m, Remove the rubber: 2 단계, 이미지 1개 중 1개
    • Carefully remove the rubber that ensures the rollers roll up and down smoothly.
    • Make sure that the rollers do not come off.
  3. How to repair a Tipp-Ex Pocket Mouse 10m, Cutting the tape: 3 단계, 이미지 1개 중 1개
    • Take the front, small and probably very full roll and unwind about 5 cm of ribbon.
    • Cut the ribbon.
  4. How to repair a Tipp-Ex Pocket Mouse 10m, Cleaning the reel: 4 단계, 이미지 1개 중 1개
    • Remove all plastic tape waste from the reel.
    • It is best to roll the waste directly into the waste garbage can.
  5. How to repair a Tipp-Ex Pocket Mouse 10m, Reattach the tape: 5 단계, 이미지 1개 중 1개
    • Cut a 3 mm wide strip of scotch tape.
    • Use it to stick the Tipp-Ex tape back onto the roll.
    • Wind a few turns onto the roll.
  6. How to repair a Tipp-Ex Pocket Mouse 10m, Inspecting and tensioning the belt guide: 6 단계, 이미지 1개 중 1개
    • Check the belt guide and tension of the belt.
    • Hold the encoder roller firmly and tighten the belt with the waste roller.
  7. How to repair a Tipp-Ex Pocket Mouse 10m, Closing the housing: 7 단계, 이미지 1개 중 1개
    • Put the mouse back together and press the lid firmly onto it.
    • If plastic parts were ruined when opening, you can glue them shut.
결론
Your Tipp-Ex Pocket Mouse is now repaired and can be used again until the tape in the encoder roll is actually empty.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
3다른 기여자 명과 함께
thst71
회원 가입일: 06/04/16
131 평판
안내서 1개를 작성함
3가이드 댓글
I dun get a single ting. Very unclear
Albrt einstein - 답글
Very bad. Not clear. Cannot understand.
Albrt einstein - 답글
Die Beschreibung ist absolut korrekt. Danke!
Angéla Schenk - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 59
지난 30일: 273
전체 시간: 38,156
