주요 콘텐츠로 건너뛰기
How to repair a bikini underwire
필요한 것
  1. How to repair a bikini underwire, Prepare the repair: 1 단계, 이미지 3개 중 1개 How to repair a bikini underwire, Prepare the repair: 1 단계, 이미지 3개 중 2개 How to repair a bikini underwire, Prepare the repair: 1 단계, 이미지 3개 중 3개
    • Identify the defective underwire
    • Push it back into the hem tunnel by hand
  2. How to repair a bikini underwire, Stitching: 2 단계, 이미지 3개 중 1개 How to repair a bikini underwire, Stitching: 2 단계, 이미지 3개 중 2개 How to repair a bikini underwire, Stitching: 2 단계, 이미지 3개 중 3개
    • Prepare the needle and the thread.
    • Starting on one side of the hem tunnel, stitch all along the tunnel opening to close the hole.
    • Repeat the process 1-2 times to make the repair extra durable.
  3. How to repair a bikini underwire, Tie-off the repair: 3 단계, 이미지 3개 중 1개 How to repair a bikini underwire, Tie-off the repair: 3 단계, 이미지 3개 중 2개 How to repair a bikini underwire, Tie-off the repair: 3 단계, 이미지 3개 중 3개
    • Finish the stitching with a knot. Cut the thread.
    • The tunnel is closed, and the underwire will stay inside.
    • Test the repair by pushing and stretching the item gently, to see whether the underwire is straining the repair. If needed, repeat step 2.
  4. How to repair a bikini underwire, Finished and ready!: 4 단계, 이미지 1개 중 1개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
2다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 32
전체 시간: 660
