주요 콘텐츠로 건너뛰기
How to repair a broken label loop
필요한 것
  1. How to repair a broken label loop, Locate the defect: 1 단계, 이미지 3개 중 1개 How to repair a broken label loop, Locate the defect: 1 단계, 이미지 3개 중 2개 How to repair a broken label loop, Locate the defect: 1 단계, 이미지 3개 중 3개
    • Locate the broken tag, and find the area where it snapped off from
  2. How to repair a broken label loop, Tidy the broken area: 2 단계, 이미지 3개 중 1개 How to repair a broken label loop, Tidy the broken area: 2 단계, 이미지 3개 중 2개 How to repair a broken label loop, Tidy the broken area: 2 단계, 이미지 3개 중 3개
    • Often the cause of the breakage, is that the sewing thread tore through the tag, leaving frayed ends
    • Trim away any damaged or frayed ends of the tag
    • Use a "seam ripper" tool, or small scissors, to carefully remove the old thread from the item
  3. How to repair a broken label loop, Re-attach the label: 3 단계, 이미지 3개 중 1개 How to repair a broken label loop, Re-attach the label: 3 단계, 이미지 3개 중 2개 How to repair a broken label loop, Re-attach the label: 3 단계, 이미지 3개 중 3개
    • Prepare your sewing machine in a clean location, and position the item underneath the needle. Depress the foot to secure the item in place.
    • Tip: for setting up a sewing machine, use the resource Thread a Sewing Machine
    • Make a short lock stitch, and then a straight line stitch from one side of the label to the other. Make a second stitch using the reverse lever, and one final stitch in the original direction. Finish with a locking stitch
    • Remove the item from the machine.
  4. How to repair a broken label loop, Trim the repair: 4 단계, 이미지 3개 중 1개 How to repair a broken label loop, Trim the repair: 4 단계, 이미지 3개 중 2개 How to repair a broken label loop, Trim the repair: 4 단계, 이미지 3개 중 3개
    • Carefully trim the thread on the outside...
    • ... and on the inside
    • Check the repair and pull the label gently to test the durability
  5. How to repair a broken label loop, Finished and ready!: 5 단계, 이미지 1개 중 1개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 39
전체 시간: 338
