주요 콘텐츠로 건너뛰기
How to repair a buckle (ski braces)
필요한 것
  1. How to repair a buckle (ski braces), Identify the defect: 1 단계, 이미지 3개 중 1개 How to repair a buckle (ski braces), Identify the defect: 1 단계, 이미지 3개 중 2개 How to repair a buckle (ski braces), Identify the defect: 1 단계, 이미지 3개 중 3개
    • Locate the part of buckle that needs fixing.
    • Note: if your buckle has actually broken or snapped, use a "seam ripper" tool, or small pair of scissors to carefully cut the threads holding the seam together. Then remove the defective buckle and obtain a replacement.
  2. How to repair a buckle (ski braces), Clean the area: 2 단계, 이미지 3개 중 1개 How to repair a buckle (ski braces), Clean the area: 2 단계, 이미지 3개 중 2개 How to repair a buckle (ski braces), Clean the area: 2 단계, 이미지 3개 중 3개
    • Use a seam ripper and scissors to cut off the damaged thread.
  3. How to repair a buckle (ski braces), Reinsert the buckle: 3 단계, 이미지 3개 중 1개 How to repair a buckle (ski braces), Reinsert the buckle: 3 단계, 이미지 3개 중 2개 How to repair a buckle (ski braces), Reinsert the buckle: 3 단계, 이미지 3개 중 3개
    • Insert the buckle in the fabric loop.
    • Check that the position is correct, and that the other half of the buckle will clip on correctly.
    • Note: It is easy to sew the clip in back-to-front - so one extra check before stitching is worthwhile!
  4. How to repair a buckle (ski braces), Stitching: 4 단계, 이미지 3개 중 1개 How to repair a buckle (ski braces), Stitching: 4 단계, 이미지 3개 중 2개 How to repair a buckle (ski braces), Stitching: 4 단계, 이미지 3개 중 3개
    • Fix the buckle in place and use the sewing machine to make a straight stitch from one end to the other.
    • Repeat the process 1-2 times for extra durability; and add a lock stitch on both ends.
  5. How to repair a buckle (ski braces), Finished and ready!: 5 단계, 이미지 1개 중 1개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
2다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 32
전체 시간: 294
