주요 콘텐츠로 건너뛰기
How to repair a hole in a crochet dishcloth
필요한 것
  1. How to repair a hole in a crochet dishcloth, How to repair a hole in a crochet dishcloth: 1 단계, 이미지 1/1
    • Collect the tools and materials you'll need.
  2. How to repair a hole in a crochet dishcloth: 2 단계, 이미지 1/3 How to repair a hole in a crochet dishcloth: 2 단계, 이미지 2/3 How to repair a hole in a crochet dishcloth: 2 단계, 이미지 3/3
    • Identify any loose loops that may come undone if any yarn is pulled.
    • Put a safety pin through the loops, this will prevent the hole from getting any bigger.
  3. How to repair a hole in a crochet dishcloth: 3 단계, 이미지 1/3 How to repair a hole in a crochet dishcloth: 3 단계, 이미지 2/3 How to repair a hole in a crochet dishcloth: 3 단계, 이미지 3/3
    • Pick one of the loose strands and tie the yarn to this strand.
    • Make three knots to ensure the knot will not come undone.
  4. How to repair a hole in a crochet dishcloth: 4 단계, 이미지 1/3 How to repair a hole in a crochet dishcloth: 4 단계, 이미지 2/3 How to repair a hole in a crochet dishcloth: 4 단계, 이미지 3/3
    • Begin your first stitch by pushing the crochet hook through the stitch closest to the tied on yarn.
    • Next, wrap the yarn in front of the hook and pull it through the stitch making sure the hook catches the yarn.
  5. How to repair a hole in a crochet dishcloth: 5 단계, 이미지 1/3 How to repair a hole in a crochet dishcloth: 5 단계, 이미지 2/3 How to repair a hole in a crochet dishcloth: 5 단계, 이미지 3/3
    • Continuing on your first stitch, wrap the yarn in front of the hook and pull it in the direction of the arrow through the loop wrapped around the crochet hook.
    • Move on to the next stitch where the orange arrow is pointing. Continue making stitches around the hole until there is a small opening.
  6. How to repair a hole in a crochet dishcloth: 6 단계, 이미지 1/3 How to repair a hole in a crochet dishcloth: 6 단계, 이미지 2/3 How to repair a hole in a crochet dishcloth: 6 단계, 이미지 3/3
    • Once you have a small opening you will now close the hole. Using the same stitch used throughout the guide, make a stitch interlocking every other stitch.
    • The crochet hook should be moving in the direction the arrow is pointing.
  7. How to repair a hole in a crochet dishcloth: 7 단계, 이미지 1/3 How to repair a hole in a crochet dishcloth: 7 단계, 이미지 2/3 How to repair a hole in a crochet dishcloth: 7 단계, 이미지 3/3
    • Continuing until the hole is completely closed.
    • Cut the yarn leaving about a 4 inch tail.
    • Pull the loop in the direction the arrow is pointing.
  8. How to repair a hole in a crochet dishcloth: 8 단계, 이미지 1/3 How to repair a hole in a crochet dishcloth: 8 단계, 이미지 2/3 How to repair a hole in a crochet dishcloth: 8 단계, 이미지 3/3
    • Using the large threading needle, thread in all of the strands of yarn.
결론
Rayme Ivers
회원 가입일: 05/04/20
157 평판
안내서 1개 작성함
UW Tacoma, Team S1-G8, Cardinal Spring 2020 UW Tacoma, Team S1-G8, Cardinal Spring 2020 회원
UWT-CARDINAL-S20S1G8
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 55
전체 시간: 2,924
