주요 콘텐츠로 건너뛰기
How to repair a torn legging seam
필요한 것
  1. How to repair a torn legging seam, Identify the defect: 1 단계, 이미지 3개 중 1개 How to repair a torn legging seam, Identify the defect: 1 단계, 이미지 3개 중 2개 How to repair a torn legging seam, Identify the defect: 1 단계, 이미지 3개 중 3개
    • Locate the damage on your item.
    • This is often in a high-stretch area of the flatlock stitching.
  2. How to repair a torn legging seam, Prepare the repair: 2 단계, 이미지 3개 중 1개 How to repair a torn legging seam, Prepare the repair: 2 단계, 이미지 3개 중 2개 How to repair a torn legging seam, Prepare the repair: 2 단계, 이미지 3개 중 3개
    • Cut away and broken thread in the area to repair.
    • Adjust the sewing machine to the Zig-Zag stitch setting, and with the correct width (it should match your flatlock stitching width).
  3. How to repair a torn legging seam, Begin sewing: 3 단계, 이미지 3개 중 1개 How to repair a torn legging seam, Begin sewing: 3 단계, 이미지 3개 중 2개 How to repair a torn legging seam, Begin sewing: 3 단계, 이미지 3개 중 3개
    • Place the garment underneath the sewing machine and depress the foot.
    • Carefully stitch all along the broken seam.
    • Take care: thin and stretchy fabric can be hard to work with. Take your time!
  4. How to repair a torn legging seam, Finished and ready!: 4 단계, 이미지 3개 중 1개 How to repair a torn legging seam, Finished and ready!: 4 단계, 이미지 3개 중 2개 How to repair a torn legging seam, Finished and ready!: 4 단계, 이미지 3개 중 3개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
    • Good to know: Because you used the Zig-Zag stitching, your repair will remain stretchable and comfy for your next run or yoga session!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
3다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 92
전체 시간: 1,641
