주요 콘텐츠로 건너뛰기
How to repair an iPhone that won't charge - Tristar Replacement
필요한 것
  1. How to repair an iPhone that won't charge - Tristar Replacement, Check for a new charger: 1 단계, 이미지 1/1
    • Your cable could be bad, try a new one, possibly MFI certified ! (Made For iPhone) Or try a known-good one.
    • Try a new charging brick, or a known-good one that delivers at least 5V-1A
  2. How to repair an iPhone that won't charge - Tristar Replacement, Checking the charging port: 2 단계, 이미지 1/1
    • Check your charging port, it could be really dirty or obstructed
    • If it looks dirty, you can take the risk to insert a thin tool and try to pry out the dirt. I am not responsible for the harm you could do to your phone !
  3. How to repair an iPhone that won't charge - Tristar Replacement, Try known-good internals: 3 단계, 이미지 1/1
    • Try a known-good battery. Replace it if your phone charges again.
    • Try a known-good Lightning charging port. Replace it if your phone charges again.
    • I know, this is a picture of an iPhone 7, check the video for the 6S on the next step.
    • The whole french version of the process, video does help if you are an english-speaker !
  4. How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: 5 단계, 이미지 1/2 How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: 5 단계, 이미지 2/2
    • If you are still reading, bad news, you probably have a motheboard problem !
    • It's probably U4500, or Tristar that's causing it, it fails very frequently on iPhones. You'll have to replace it.
    • Video tutorial for Tristar replacement on iPhone 6S
결론
다른 12명이 해당 안내서를 완성하였습니다.
Alexandre Isaac
회원 가입일: 04/07/13
2,863 평판
안내서 8개 작성하였습니다
The Repair Academy The Repair Academy 회원
Business
1 회원
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 95
전체 시간: 10,883
