주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    This is a hyper extended end of a magsafe.  It is no longer working due to the wire having pulled apart.
    • This is a hyper extended end of a magsafe. It is no longer working due to the wire having pulled apart.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use wire cutters to cut the wire of the magsafe some distance back from the magnetic end. I cut about 4 inches back. You can get much closer like maybe an inch, as you will see in the next step.
    • Use wire cutters to cut the wire of the magsafe some distance back from the magnetic end. I cut about 4 inches back. You can get much closer like maybe an inch, as you will see in the next step.
  3. 필수 도구 키트
    최고의 소형 키트에서 가장 유용한 도구.
    지금 쇼핑하기
    필수 도구 키트
    지금 쇼핑하기
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    I used a utility knife to cut the nice white cover off the tiny printed circuit board.  There is a molded plastic cover similar to hot glue which had to be stripped off the PCB.
    • I used a utility knife to cut the nice white cover off the tiny printed circuit board. There is a molded plastic cover similar to hot glue which had to be stripped off the PCB.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    1.) Take the good end of the existing wire and strip it.
    • 1.) Take the good end of the existing wire and strip it.
    • 2.) The interior wire, which is coated in white should be soldered on a square metal plate about one eighth inch square. This plate is opposite a small chip for reference.
    • 3.) The braided wire coats the white interior wire, and is wrapped around it in two different directions. This wire should be peeled off and then twisted together.
    • 4.) Then solder it in place opposite the chip and the other wire.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    • Plug in wall outlet and install on computer to test.
    • At this point there are still exposed live wires carrying DC voltage. To eliminate risk of shock or shorting, cover the bare wires in electrical tape, heat shrink tubing, or Sugru.
결승점
다른 20명이 해당 안내서를 완성하였습니다.
040304
회원 가입일: 2009년 11월 05일
9,431 평판
안내서 1개 작성함
Thanks a lot for the tutorial, worked like a charm and the result is quite clean too. You made me save 80€!
Aurelie Aurelmaispasmarc - 답글
Works but looks like !@#$.
Peter Mortensen - 답글
If it looks stupid, but it works, then it's not stupid. I'm certain someone has the skill to make that end look good.
040304 -
Awesome! I had not used my macbook for almost a month, since my magsafe quit working. I was afraid to cut into the plug, fearing I might damage the circuitry inside. Once I saw the pictures of the inside of the adapter, I knew the correct way to do it. Thank you for the tutorial. :)
Reilly McGinnis - 답글
Could you please make the same guide for a L connector?
luca - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 49
30일 전: 189
전체 시간: 109,338
