소개
Microsoldering technique for replacing a faulty IC to restore touch functionality in the iPhone 6.
도구
부품
지정된 부품이 없습니다.
In this tutorial you will learn how to resolve hardware touch issue in an iPhone 6 smartphone. In case of any troubles contac me through the comments.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 8개
Do you change that ic with new one?
thanks before
aqsha asri - 답글
No, I have desoldered the proper chip from the other motherboard. Thanks for your interest and best luck with the repair!
Is it a good idea to change the whole screen
You are right, but sometimes it won’t work. Especially when it is a hardware issue.
? the logic board is not attached to the screen ... it has nothing to do with the screen, it is that - processor where one of the soldering points is not making contact and the tutorial shows just reheating to the point the soldering melts again and the crack or whatever that makes the connexion is broken gets fixed again, right?
